Question about LG Televison & Video
Hello, my LG 37LG5010 <37LG5000>
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
  • 4234 Answers
SOURCE: Volume is not controlling press up button it goes
It is possible that the tact switches are defective, buty to have 2 fail in the same manner at the same time is extremely rare. More likely there is a problem with the 5V line from the power supply that is allowing some AC current to flow onto the 5V DC line. I can't confirm this without actually seeing the set and taking measurements, but try changing the volume using the remote, if the behavior is the same as with the fron butons, then have a servicer check the 5V DC line.
Posted on Dec 08, 2009
  • 11361 Answers
SOURCE: we have a samsung tv
Similar to this?
It can be T-CON, Power supply, LCD panel.
Learn more about T-CON/LCD panel here (not just for SONY TV): PDF download
Also read my guide:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 11, 2011
  • 26 Answers
SOURCE: Television volume down button sticks.
spray windex or 409 on the button n press it as you spray it n around the button. Loosen the grime in and around the button.
Posted on Sep 24, 2012
  • 74999 Answers
SOURCE: Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Posted on Dec 05, 2012
either a problem with the menu button on the set (they can act up even if never used) or with the microprocessor in the set.
EL quapo esta aqui
Mar 13, 2012 | LG 37LG5000 37 in. HDTV-Ready LCD TV
37lg5000 tv picture starts to flicker and goes dark.
that is cause by a loose connectors or a cold solder joints of parts the repair of this kind requires opening the cover .re solder all connectors terminal and re insrt all socket connectors ..
Sep 30, 2011 | LG 37LG5000 37 in. HDTV-Ready LCD TV
Ltv30w2 what part needs replacement when audio/video just quits after about 10 min. ? signed; rod. ( used to repair black and white t.v. 's before color was invented ) &lt;...
Hello Friend,
This issue seems to be due to over heating of power transistor in the power supply unit. Try replacing them. Also replace main big capacitors which could be leaky around that transistor . your issue should be resolved with this.
Dec 19, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Feb 17, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Open Questions:
I have a LG 50 LCD TV Model: 50LN5700-UH that has a black screen. There are a couple of things I have tested and replaced. First off there is audio but just a black screen. I turned off the lights and looked for signs of back lights. When I did this there were no visible signs of lights. In addition, I did the flashlight test. Which showed visible signs of lettering on the screen with the flashlight. Which if I understand correctly it may determine that the T-Con board is functional. I ordered additional LCD's from Shop Jimmy and replaced the bad sticks. About half were replaced. I reassembled the TV and I am still getting no video, but I still have audio. However, this time all the LCD's are functioning so now the screen is still more grey than black because of the working LCD's I replaced. What voltages and at what points should I be testing to narrow down the problem, or what other problem-solving technique should I be testing? One other thing I should mention is there no visible signs of swollen capacitors or any signs of burn marks. I am 99% sure I connected all of the cabling up correctly, not 100% since this was my first attempt but I am a little less confident I put the filters in the correct way. I had the TV disassembled while I was waiting on the LCD's to ship and when I re-assembled I was less confident if I picked up all 3 or 4 filters and set them down, or if I make have flipped the filters to keep the circuit board on the front cover from being damaged. Hope that make since.
Mar 16, 2018 | LG Televison & Video
Televison & Video Logo
71 people viewed this question
Computer Repairing
Computer Repairing
