Question about Moen & One Handle Tub & Shower Faucet
Handle is very hard to turn. what is wrong - Moen & One Handle Tub & Shower Faucet
  • 59 Answers
First, turn off water supply, then remove screw from center of handle, unscrew cover plate. There is a round mixing valve that will need to be replaced. You can find at any Do it yourself or hardware store. Dont forget to turn off water supply first........
Posted on Apr 07, 2011
Universale
Did you set the flapper chain into the correct potition on the handle? Universal handles usually have three settings for length and holes to fine tune the position. If you put the chain in the wrong place its hard to get the correct adjustment on the chain.
Aug 23, 2014 | Home
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
Window handle turns but won't unlock
You are in the wrong product section. Please select the correct category and repost.
Jan 22, 2014 | Cars & Trucks
When I screwed down the top plate (10 screws) on the Hayward vari flow valve I lose spring tension and cannot turn the handle. Have I put the spring etc back in the wrong way or have I done something...
From the breakdown sheets I see no way that the spring would not allow the handle to turn. It looks to me like it is only used to help keep the handle in the locked positions. I would say you have another issue. Try lubing the valve o-ring to help it keep from sticking.
Apr 10, 2013 | Pool & Spa
Faucet handle turns wrong way
You bought two cold water faucets. The threads are reverse on the hot water faucet. Exchange the wrong one at the store you bought it from.
Dec 31, 2012 | Moen Plumbing
Stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
The man remodeling my bathroom says I received two left handles on my roman tub faucet..but I noticed the tiny small screw on each handle going in the same direction on each handle ..did he put it in...
No, he is right, the handles turn in opposite directions... the cold CW and the hot CCW... you cannot change the direction of the on/off sequence...and the rotation direction... so... yes you will need to send back the wrong one and get the right one or send back the whole set and get it replaced...
heatman101
Dec 09, 2010 | Delta Home
Bissell Pro Dry will not turn on.
it's either the motor blew or something in the motor popped out of place, I have the same steamvac and it has done that before. Take it into a vacuum shop
Sep 11, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
2-handle faucet handles both rotate "on" counter=clockwise
Here's the solution from Delta:
On a two-handle kitchen or lavatory faucet, if the handles rotate in the wrong direction, simply rotate the right stem stop assembly 180 degrees. This will change the rotation of the handle to the other direction.
Jun 23, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Moen & One Handle Tub & Shower Faucet  Logo
803 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
