Water pumps out real slow - Washing Machines
  • 93 Answers
Based on experience, your pump may be partially clogged with dirt / debris . You'll have to unplug the power cord. Turn off the water. Pull machine away from wall as the pump access panel is in the rear. Remove panel, remove pump. Yes, it's gonna be messy. Have plenty of towels on hand. Once the pump is removed, disassemble and clean it out. You may get lucky if your pump is made from translucent plastic, you can actually see if it's clogged before having to remove it .
Posted on Apr 07, 2011
    Sergeant:
    Champion:
  • 202 Answers
Hi... If its pumping out slow ..your going to need a new pump soon
Front loader goes up real slow and on down pressure
not eneough information need maker and model
doesnt sound like a control panel fault
if a filling up problem
faulty water intake solenoids
or if not pumping out ... the water pump
if its a spinning and washing fault
the motor worn out .drum shaft support bearings
Apr 30, 2016 | Washing Machines
How do I figure out water pressure?
There should be a check on the suction side, and a gauge on the pressure side. Pressure comes from flow being slowed down or stopped. If the outlet is full open, no real pressure will be seen.
Aug 18, 2015 | Utilitech 1-1/2 HP Irrigation Pump UTP15P1
Pulse changes speed on baracuda
as there are no real moving parts on the barracuda, the pulse is driven by the efficiency of the pump. if there is air in the system, the pulse will slow down. as the air is expelled and the pump becomes more efficient at moving water, the pulse will increase.
Aug 23, 2014 | Zodiac Baracuda G3 Automatic In Ground...
Hard to refill gas tank have to pump real slow car runs fine
You've got your gas tank presure release valve.stuck or no good
Jul 15, 2014 | Hyundai Motor 2003 Sonata
I have a maytag neptune washerModel no# MAH5500AWW not draining and spring real slow?
when it is not draining the first thing to do is to check the drain itself. locate the pump it will be on the bottom of washer, there will be a hose that runs from it. follow the hose and it connects to a cleanout u may have to disconnect the hose to make sure it is not blocked. check the discharged hose as well. if everything is clear then u my have a bad pump. when u turn on washer do u hear the pump come on to try to pump out water? the reason it is spinning slow is because there is still water in the tub.
Apr 15, 2014 | Washing Machines
Just bought a second hand 40hp tohatsu took it out bu water was not continuly coming out when motor is running have stripped down and parks all look ok in shaft. Also what gasket sealer should i use when...
you have a thermostate water will come out real slow till it warms up should get full stream when full open if not change water pump and thermostate
Jan 03, 2011 | Boating
Water is filling up the dishwasher real slow and the wash cycle starts when the water level is not full. I have changed the electric pump, the hose, and the turn off and on valve.
You have changed the components that I would have taken a look at, which is a good start. From the information you are telling me it maybe the water level sensor that is malfunctioning.
May 14, 2010 | Frigidaire PLD4555RFC Dishwasher
Coffee maker is not pumping water fast enough. takes over a minute to brew a 8 oz. cup. pumps water real slow.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Nov 04, 2009 | Keurig B60 Coffee Maker
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
