Installation program indicates invalid seriel no
    Novelist:
  • 173 Answers
What type of program are you trying to install on the laptop?
it only means the serial number that is included with your program either not valid(used) or incorrect.
Posted on Aug 06, 2008
SOURCE:
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
I have CreataCard Platinum 8 version installed on my computer. Recently, I had to uninstall it and then re-install it due to some computer problems. I just tried to access the program and I keep getting...
Hi.
If you are unable to uninstall the software by way of 'Add or Remove Programs' or 'Programs and Features', it will be necessary for you to perform a manual uninstall by searching the hard drive for files and folders related to the program you want to uninstall. then manually removing those files and folders.
Many programs will install files and folders in several locations on the hard drive. And, even when it is possible to uninstall software by way of 'Add or Remove Programs' or 'Programs and Features', it is always a good idea to conduct a search of the entire hard drive then manually delete any files, folders, icons and shortcuts that are found by that search because many uninstall processes do not remove all files, folders, desktop icons and Start menu shortcuts associated with the software.
After making sure that all files, folders, icons and shortcuts have been removed from the computer, empty the Recycle Bin, restart the computer, then run a registry cleaner until no invalid registry entries are found. It is advisable to run the registry cleaner REPEATEDLY (always restart the computer before running the registry cleaner again) because fixing some invalid registry entries can cause other registry entries to become invalid.
If you are uninstalling the program because you believe that the installation is corrupt, these steps are especially important . Making sure that all files, folders, icons and shortcuts are manually deleted and using a registry cleaner to remove all invalid registry entries is the best way to ensure that all corruptioIf you don't have a registry cleaner installed on your computer, you can download the free CCleaner by clicking on the link below
Download Latest Version of CCleaner
If you use CCleaner, you must remember to click on the 'Registry' button on the left side of the window before starting the scan. And, with CCleaner, running the registry cleaner repeatedly will often cause the same invalid registry entries to be displayed over and over. If that happens more than twice, the only option is to allow those invalid registry entries to remain - because indications are that those invalid registry entries are not truly
invalid at all.
There is also an option to try and uninstall a program using CCleaner. If you click on "Tools" option on the left hand side, click on "Uninstall" and look down that list for Creatacard and try and uninstall the software using that option.
The 'Cleaner' option in CCleaner is a very useful tool for cleaning out unnecessary files and folders on the hard drive. So, it is also be a good idea to run the 'Cleaner' option in addition to the 'Registry' option.
Once you are sure that all traces have been removed restart your computer and proceed to re-install the software again.
Hope this helps.
Regards.
Jun 02, 2011 | Broderbund American Greetings Creatacard...
What a serial number for instalation of program?
this usually comes with the installation CD. You can contact the manufacturer for another seriel number or another \installation cd for a fee if you have lost yours.
Aug 07, 2010 | Computers & Internet
In need of my acura radio code. Bought my car RSX used. When I had to get my car jumped, the radio went to ''code''. After researching on line, I found out how to get my seriel # and the previous owner...
The dealer can help you. No one here is going to give you a code for a possibly stolen radio and the dealer will not do it over the phone. That is my experience with BMW. They need to make sure you actually own the radio or the whole security scheme is invalid.
Jan 24, 2010 | 2002 Acura RSX
Control code
leoidalgo
I have provided the remote codes for your Zenith TV. I have also provided a link with instructions on how to program the remote to the TV. I hope this helps.
Remote codes: 501, 652, 766, 500
Program remote, step 6:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Jan 06, 2010 | DISH Network 142923 Remote Control
The seriel number provided on disk sleeve will not work.
The installation program for the WINDVR 3 program isn't looking for the serial number of the TV Tuner card. It's needing your registration serial number when you paid for the software. I found a serial number that worked for me (after looking for 4 hours!!). Just enter this serial number and it should work for you. Be sure and put something down for your company name, also. Here is the serial:
kC7G94GSAE08A0S
Jan 01, 2010 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
NEU SERIEL NUMBER FOR DOWNLOADED ''NERO7'' PROGRAM.
If u want a new serial Number then mail me on [email protected].
I will definetly send you a new serial number of your own name.
plz dn't forget to rate my solution.
Nov 16, 2008 | Wasp 31518
I get an error 6 the handle is invalid
While running setup or autorun file directaly from the CD error msg comes as:- The handle is invalid
Email :- [email protected]
Jul 24, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
52 people viewed this question
Ekse
Alun Cox
