Question about Brother Sewing Machines
My machine keeps getting jammed after the third stitch. When I lift the feeder, the top thread is tangled up. It seems that something underneath is pulling at the thread. I replaced the bobbin case so I don't think that's the problem. Please help!
    Genius:
  • 1,788 Answers
The problem is in the bobbin area. I would take it in for repair because you timing may be messed up.
Posted on Apr 10, 2011
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
I keep having problems with the stitching on my machine. 1) when you sew the stitches looks normal from the top but when you turn the material over it looks like one big tangled mess. 2)When it does...
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
Sep 26, 2010 | SINGER 7470 Sewing Machine
Bobbin thread is balling up underneath and not allowing more than a couple of stitches before jamming.
Totally rethread your machine and install a new needle. Your thread could be tangled. Usually the top threading is the culprit, not the bobbin. Check your manual, it is surprising, sometimes you think that you have it threaded right and it isn't.
Sep 06, 2010 | Sewing Machines
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Birdsnest and machine jams
Ok, this is real simple. pull the thread from the bobbin up through the bottom of the machine near the needle. also, hold the thread that you threaded through the needle with the other strand on the left of the needle. hold them there for a few stitches... and wahla! no more birds nest.
May 10, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
131 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
