Question about Microwave Ovens
I have a Sharp Carousel MOdel # R149. The door latch is loose. Spring on the latch is broke or out of position. How do I get to the latch that is inside the door panel to replace the spring ?
  • 59 Answers
You have to lift door off pins. Use a flat head screw driver to pry inner panel of door to get to latch.
Posted on Apr 07, 2011
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
Sharp carousel microwave R216 LS door latch has a problem. It won't open and feels like there is just a spring inside. I dont know if I can open it and fix it.
It's probably a broken door open lever or door open button.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Oct 18, 2011 | Sharp R-216 800 Watts Microwave Oven
I have a problem with my Sharp Carousel R 1480. The door will not latch and the light will not go out. The hooks on the actual door seem to be in place and working like normal so Im assuming it is...
We have the full service manual at our site here.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
In some cases, you problem may be a damaged latch head, which is an odd name for what I would call a door switch holder.
Our file on door switches is here.
You can order parts from Encompass Encompass here or you can call them toll-free at 866-779-5835.
Oct 01, 2010 | Sharp R-1480 Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Door does not latch when closing on Sharp Carousel model R1480 Ser.# 221885 Microwave oven
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the internal spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here but the best place to order Sharp parts is Tritronics.
Nov 05, 2008 | Microwave Ovens
We have an old Sharp Carousel R-1440 that works great, except for the door latch broke (i.e. doesn't work at all now). Can we replace just the door?
Actually, the door latch head (hooklike device) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have critical safety & disassembly info at our site, linked here.
Sep 27, 2008 | Sharp Microwave Ovens
Sharp Carousel Microwave door latch stopped working door won't stay closed
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 18, 2008 | Sharp R-1480 Microwave Oven
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
167 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
