Question about HP PSC 2210 All-In-One InkJet Printer
Ihave a hp all in one printer scanner and copier, there is dust under side of glass how do I clean it the model is b110, been like it from new don't seem to be able to get hold off hp
    Habit-Forming:
  • 23 Answers
HP says below that for your printer it can't be cleaned except by an authorized dealer. I know from experience that flat bed scanners/all-in-one's have small holes in and around the tray that houses the scanner assembly. If you take canned air and use the long straw that comes with it, you can usually do a fairly decent job cleaning the underside of the glass. It won't necessarily be perfect, but I've found that it's better than what I had before.
You may be able to find several spots to feed the straw through to blow air at the glass.
PLEASE....DO NOT TURN THE CAN UPSIDE DOWN AND SPRAY. You'll inject liquid into the scanner assembly tray and onto the glass. Have someone help you turn the printer upside down or on it's side if you need to get the angle to spray.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=us&lc=en&dlc=en&product=79499&tmp_track_link=ot_search#N89
Flatbed products have a large scanner glass under the top cover.
NOTE:
The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
Regards
Posted on Apr 07, 2011
Hp laserjet 4345 when scanning from adf copies too light
Take copy with default settings, if quality is poor, need to clean inner parts like reflecting glass, engine reflector of optical scanner assm(CCD)..& flat bed glasses both sides.
Note: with out proper knowledge pl don't open this printer..
Sep 30, 2011 | HP LaserJet 4345mfp Printer
When I try to copy a letter or anything, a black line shows up down the center of the printed copy. How do I remove this?
look at the scanner glass. It probably has some dust specs on it, clean it . Also clean the small glass toward the left of the scanner glass. If the dust specs are under the small glass, you can carefully remove the glass and clean it.
Jun 28, 2011 | HP Photosmart Premium C309A All-In-One...
A black line prints down the left side of anything I copy or scan
Probably there is piece of dust, or some dirt (usually a pencil mark) on the scanner glass, which is located under the front panel. Open the front panel and clean the glass with a soft cloth. If necessary, use some liquid cleaner, but put it on the cloth, not directly on the device.
This link might be helpful.
Nov 05, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
HP All-in-One 3055 "Scanning Error 6" What can we do?
Hi Cherylanne, Give this a try: Scanner Error 6 Turn off then on
1. Clean Glass Scanner Bed.
  • If the glass scanner bed is too dirty or smeared with fingerprints and such, you may get this error. It will not clear itself simply by turning off and on the printer such as the message suggests. Even a build up of dust can cause this. It is triggering a reaction caused by a sensor in the scanner. If you clean it good and then power cycle it, the problem should go away. THIS PROCEDURE FIXED THE PROBLEM FOR THE AUTHOR.
2. Try the NVRAM INITZ reset procedure. REF
  • switch off the printer, then remove all cables connecting to the printer but just the power cable.
  • then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
  • continue holding the button till you see "perment storage init" displayed and releas the button.
  • then at a given point of time the printer will ask you to change laguage,time,date etc.
3. Remove paper scrap or dust obstructing scanner or sensor. REF
4. Clean sensor / remove the glass and clean the bulb and mirrors. REF
  • turn off power
  • remove ADF and inspect blew out any dust
  • unclipped control panel cover and removed top platen cover 4 torx screws
  • inspected and dusted (blew out) the scanner
  • put platen cover back again and placed 5 sheets new paper over right side (where scanner is) and turned on came up happy
  • turned off reinstalled ADF (cleaned the white surface first) turned on again
5. Scanner Bulb is not getting to the alignment area.
Information found @
http://wiki.robotz.com/index.php/HP_LaserJet_3055
Regards
Mike
Oct 12, 2010 | HP LaserJet 3055 All-In-One Printer
I need to clean the under side of the glass.
Cleaning the glass on what we call a "disposable printer" can be interesting. The simple process is to start pulling screws that appear to permit access to the scanner bed. For Lexmarks this generally involves an almost full disassembly of the machine. If you do get it apart be very careful not to let any dust or debris or solvents get near or on the scanner head, this will likely prevent it from properly calibrating and stop the entire machine from running. New all-in-one machines are generally designed so that if one function fails, the entire machine fails. I would say to just purchase a new machine, a repair bill will easily equal that cost and a novice repair job has a good chance of rendering the machine inoperable.
Jun 08, 2010 | Lexmark X5150 All-In-One InkJet Printer
HP 6110 CLEAN GLASS ON SCANNER UNDER SIDE
Those models are difficult to open, they are all torx screws, all around the outside, screws in the front under the control panel, one screw under the narrow glass on the left. two screws at the back and another 2 on the right.
Dec 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
HP C4385 Printer/scanner/copier glass bottom side needs cleaning
there are 4 screws on the sides remove these and the rest are clips
Oct 26, 2009 | HP PhotoSmart C4385 All-in-One Printer
I don´t know where is located the scanner glass in my hp psc 2110 all in one
The Scanner glass is located on the top of the device under the grey cover (This cover will lift exposing the scanner glass)
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Officejet J6480 has scanner failure
sometimes cleaning the scanner glass plate would fix this issue.
turn of the printer.
wipe the scanner glass flat form with with a cleaning wipes or a plain water and a tissue (just a little water in the tissue). make sure the glass is clean with dirt and dust.
turn on printer.
hope this helps, please rate.
Feb 07, 2009 | HP Officejet Wireless Multifunction...
HP PSC 2210 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
