Question about Lexmark X4650 InkJet Printer
How do i connect my laptop to printer over a wireless network
    Master:
  • 395 Answers
First you want to make sure your printer has wireless capability. If yes, you want to make sure wireless is turned on. Log into your wireless router, and go DHCP section to find out what IP that assigned to printer. Once you know the IP, you can change the port of printer to that IP via control panel and printers and faxes. Good luck and let me know if need additional help.
Posted on Apr 07, 2011
My pavillon 9910 series 32 bit cannot find my wireless printer photosmart 7515 all in one printer?
Does your printer connect to your network ok? Have you connected it to your wireless network before trying to "find" it on your laptop?
Does your wireless network have a router/switch/firewall?
Jul 18, 2012 | HP Pavilion DV9910US Notebook
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Hi i have the canon mp490 all in one printer and i was just wondering how to i get things to print from my lap top
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
Aug 05, 2011 | Computers & Internet
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Can I wirelessly connect a laptop to this printer -
If the printer you want to connect the laptop to is a wireless printer you should be all right.
Have you configured the wireless adapter on both the printer and laptop for the correct freq or channel?
Aug 18, 2009 | Canon Office Equipment & Supplies
Laptops not connecting to the internet when the hp c4599 is on
Perhaps the printer is conflicting with the laptop by taking its "address" on the network...Do you know how to give your printer a diifferent IP address? Or your laptop? Its a bit complicated to explain but if you can make sure the laptops and the printer are all set to use "DHCP" then they should all each get an adress on your home network and work together.
In Windows Vista, click Start, Control Panel, Network & Internet, View Network Status and Tasks. Then view the status of your Wireless Network Connection and click details, if it says "DHCP Enabled" in there then your laptops are not the problem and should be sharing addresses.
You should be able to see in the printers control panel or by printing a self test page how its setup on the network, maybe it needs to be reconfigured while the laptops are turned on as well.
May 17, 2009 | Office Equipment & Supplies
Connect a wireless laptop to an existing wired network printer
Hi!
Its designed for wireless, but you need an adapter to make it wireless, the adapter
"Dell Wireless Printer Adapter 3310 USB2"
I dont know if that adapter came whit your printer when you bought it, but thats what you need to make it wireless
Good luck
Nic
May 13, 2009 | Dell 5100cn Laser Printer
Printing remotely from laptop -- can I?
I assume it's a Brother printer not your brother's printer right? I have an HP and it's a wireless printer which is accessible through my network, you have to install the printer driver and software on to the other laptop that is connected wirelessly to your network.
Mar 31, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Oct 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X4650 InkJet Printer Logo
89 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
