Question about Estate Refrigerators
The freezer works properly, but refrig part does not cool to proper temperature. Have checked doors and cleaned behind.
  • Estate Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 08, 2011
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
My frost free fridge freezer comes on for five minutes every half hour and is not cooling very well, what's the reason for this?
1 Check the thermostat settings i.e. temperature control. Hope it is not on the lower number. 2 If the thermostat setting is OK then there is every possibility that the cooling gas has leaked out. Call the technician and get it recharged. 3 Also check the compressor that it is working properly.
Jul 31, 2010 | Refrigerators
My GE freezer stopped cooling. I turned it off,
Hi
I think the problem you are experiencing might be due to the temperature control.
1. Check if the temperature control is off if you dont hear the freezer operating.
2.If you do not see an interior light,when you open the door,then make sure the freezer is properly plugged into an electrical outlet.
3.Move the temperature level to a colder level if the freezer is not cold enough.Warm weather can also be a factor.
4.Find the condenser and check to see if it needs to be cleaned. The condenser is located behind the decorative paneling at the bottom of the freezer.
5.If it doesnt work still then contact a technician.
GOODLUCK
Jul 28, 2010 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
I REPLACED THE DEFROST ASSY COMPONENT ON MY JENN-AIR REFRIG, BUT STILL WON'T COOL ENOUGH. fREEZER WON'T FREEZE side by side jcd2289
Make sure both fans are running and check that your the coil is not frozen. The coil is behind the freezer panel.
Jul 02, 2009 | Refrigerators
My westinghouse fridge is not cooling but the freezer works fine
There isn't a fuse in the refrigerator. Check to see if the fan in the freezer is running, you should be able to hear it when you open the door unless it is a very old refrig. See if there is any frost or ice on the back wall inside the freezer. If so, you have a problem with the defrost system. If you do not hear the fan running it may have failed.
Apr 08, 2009 | Refrigerators
The panel between the two doors are heating up as well as on side panel of freezer. The freezer is only cooling down to -8 deg Celsius. The door is closed properly.
you need to check the condenser fan motor located in back of the refrig behind cardboard cover. most likely the motor is bad or something is obstructing the fan from turning. also be sure the coil under the unit is clean as well. temporarily you can place a house fan blowing in the rear of the unit to keep it operating normally until you get it repaired.. peyton
Jan 25, 2009 | LG LRSC-26922 Side by Side Refrigerator
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
147 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steven Clarke
Steven Clarke
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
