Question about Samsung Refrigerators
Samsung refrigerator model #RS2533SW sserial#755843CTA02409 N HAve power at main proccessor and power to control panel on door no lites on control ponel nothing working ,compressor not running evap fan not running not in drfrost , only thing working is lites inside both frezzor and refrig
  • plnt_mngr Apr 07, 2011
    board in back of unit or board in door with the buttons and lites on it ? just want to be sure were on same page Thank you very much
  • 10,515 Answers
This is a common problem. The situation you mentioned is highly suggestive of faulty control board ( or call as motherboard ). You could try to unplug the refrigerator for few minutes, say 15 minutes and then turn it ON. If you do not see any improvement, it would confirm faulty control board and needs replacement.
However, there were few models in the past which had a reset option where you need to hold the power up and power freeze pads at the same time until their little lights come on then you press a small square button on the ice-maker then the compressor and fans start up.
Thanks and Regards
taran_2005
Posted on Apr 07, 2011
  • taran_2005
    taran_2005 Apr 07, 2011
    Thanks for your response!!
    I was mentioning about board in the back of the refrigerator which is commonly known as motherboard.
    Thanks and Regards
    taran_2005
Samsung refrigerator alarm beeping continuously
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung Refrigerators
My samsung frige, french doors keeo ringing
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 19, 2015 | Samsung Refrigerators
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Samsung model rs2533sw control panel not coming on
http://www.fixya.com/support/t1914675-control_panel_not_working_samsung
Nov 30, 2017 | Refrigerators
Water Filter not filtering
DID YOU ALIGNE THE INDICATOR MARK (UNLOCK POSITION) AND PUSH IT UP WHILE TURNING 1/2 TURN UNTIL THE LOCK POSITION IS ALIGNED. REMEMBER TO NOT TO OVER TIGHTEN THE FILTER.
Mar 04, 2009 | Samsung RS2534 Side by Side Refrigerator
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
501 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
