Question about Home
Tell me how to clean my Lasko tub surround. What type of cleaning products should I use and how often?
  • 718 Answers
Are you new to this cleaning stuff?? You should probably go to your local home center and ask some questions or hey I have an idea go to the lasko web site?? Just git er done now Judith!!!!!! ANd have fun doin it K.
Posted on Apr 07, 2011
Cleaning lasko 2137 window fan
These are tamper proof screws and require the proper bit for removal. That is not a common bit and is used only in mass production environments. Use compressed air for cleaning
May 18, 2017 | Cars & Trucks
How to remove lent and dust from the sides. What type of tool is needed to remove the two sides for cleaning.
ther are cleaning brushes out there. look like a stick with a brush head on it. they have them in hair cutting equipment.
Sep 29, 2013 | Lasko High Velocity Space-Saving Blower...
Oil type substance is streaking down the side of the tub and apperars to be coming out of the jets any ideas how to fix it
This sounds like bacteria coming from the water lines. When was the last time you ran a cleaner through the jets?
You should run a good Jet Clean type product of Maintenance Product in order to prevent the build up of bacteria in the water lines when the bath tub is not in use.
RodUS Parts Center888-521-6183
Feb 22, 2013 | Home
What type of screw driver do u use for a lasko 2543 tower fan? I would like to clean it and have never seen screws like this.
You may need to check the owners manual. If you have lost the owners manual, you can download a new from this site for free: http://www.laskoproducts.com/?s=Manuals... Just type "Tower Fan" in the search box and browse through the results until you find your model.
Aug 07, 2012 | Lasko Products 41" Elite Tower Fan 3spd -...
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Need installation instructions for ASB model# 36850 Hudson tub surround
This is a 5 piece surround. For this project you will need the surround, polystryene adhesive, a utility knife, caulking and caulking gun, dish soap and the box the surround came in. On this type of surround the back and end walls are installed 1st and then the corner shelves are installed. Ensure the wallboard or substrate is clean and free of contaminates. Best to install new backer board or moisture resistant drywall first before proceeding. You will need adhesive specifically designed to glue the panels and corner shelving to the walls. Common product is PL700 from Lepage. Follow the manufactures instructions for the adhesive you are using. Avoid any adhesives not approved for use with plastics as they will damage the surround. Remove the tub spout, hot and cold water handles and diverter handle if your shower is equiped with one. Common diverters are a pull up on the tub spout. Install the panels with the bottom edge directly on the tub deck. For the end panel where the plumbing comes through you will need to cut access holes. Use the box that the surround came in as a template so that you are not accidentilly cutting holes in the wrong location. After installing the panels and shelving corners you will need to seal the seams with 100% silicone caulk. Peel the shelf edges back slightly and run a bead of caulk underneath the seam. Smooth the caulk line out. TIP Use a latex glove and dip your finger in dishsoap. The silicone will not stick to the dishsoap and will leave a clean fine line. Run a 1/4 bead of silicone where the surround meets the tub and also where the plumbing goes through the surround. Allow to dry and cure as per the manufacture's suggestions. TIP Install expanding foam in the cavaties of the shelving. This will provide a more rigid shelf and will extend the life of your new tub surround. Good luck with your project.
Jun 16, 2010 | Home
How do you clean a tower fan?
How do we clean the Lasko 2554 tower fan filter please some one help email me at dutchlady_49@yahoo.com
May 05, 2010 | Lasko 2554 WIND CURVE Fan
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
Aug 01, 2009 | Lasko High Velocity Space-Saving Blower...
How do I clean my Lasko fan with Ion?
Yes unscrew the screws and thre will be more screw to undo insode to take it apart. I had to do mine an it was filthy! Good luck!
Apr 23, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Home Logo
115 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
