I have an Ideal Isar m30100 boiler but have no manual. The boiler is taking ages to heat the water? And when the heating is off the radiators are stll red hot? there is the letter "t showing on the display but I don't know what it means.
SOURCE: I have a vitodens 100-w
new diverter valve
Posted on Nov 25, 2008
  • 13 Answers
SOURCE: Vaillant boiler (VCW GB 221)
The movement of the diverter valve is critical on this appliance, and is located on rear right of the boiler, when hot water is turned on, theres are two microswitches, which must break (they both close in Central heating mode), if pump is running, it is recognising the hot water demand, check microswitches are breaking, if not, it tends to be a defective servo valve (located above the water valve), or a blocked/ restricted control line (small copper tubes which connect into the servo valve)
Posted on Mar 03, 2009
  • 234 Answers
SOURCE: I need an Instuction manual free to download for
http://www.screwfix.com/talk/thread.jspa?forumID=25&threadID=27577&messageID=268842
I hope this help you.
Posted on Mar 19, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Posted on Apr 21, 2009
shastalaker7
  • 1515 Answers
SOURCE: Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Posted on Oct 31, 2009
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Engine over heating
The heater core is acting like a small radiator and is cooling the system when it is on. That means that the main radiator on the front is not working. You need to take the cap off and look inside to see if there are a lot of minerals or other deposits that are blocking the flow inside that radiator. If there is none, check the radiator fins on the outside of it and see if they are smashed flat or obstructed with dust, mud or other debris.
Mar 30, 2014 | 2001 Land Rover Discovery Series II
Boiler keeps blowing fuses in pcb ideal isar he 30
The model # you listed is for a vent-free, natural gas, space heater and requires no electricity to operate. Unless, you have the optional blower. If the blower accessory is what's blowing the fuses, there is a short in wiring to the blower motor. Other than that, there is nothing else about this heater, that would be blowing fuses.
Is the above, the problem you're having? If so, unplug the blower from the wall outlet, until it can be repaired or replaced. The heater will continue to operate and heat with out the blower.
For more information about your heater, go to the link below.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107882-01.pdf
Mar 04, 2011 | Desa International CBN30T Central Heating...
Ideal isar 30 he making noise when going too low falme checked condensate trap replaced pcb n fan still noisy when on low flame
. is the flame detection probe or its wiring harness, this sits right on the heat ex and over time melts and sticks to the heat ex so looses continuty.
To check if the detection probes faulty, get a multimeter pull the wiring off the probe stick one end of multimeter on probe connection, other end to the wiring plug, set your multimeter to mirco volts. fire boiler up. you want more than 1.5MV's or probes is knakered! Check continuity of wiring, also check wiring is full pushed in to the white molex connector too.
May 14, 2010 | Heating & Cooling
Broken heat exchange in boiler leaking hot water onto pilot light
Maang, You are a year older than me, so lets see if I can point you in the right direction.(1) If you have access to the internet you should be able to find a manual for an "Ideal Classic Boiler".(I just did) but you'll need to print it out - 40 pages. (2) It is 12 years old and is past it's half life. You might consider a whole replacement boiler - installed by a professional contractor rather than replacing a cracked section of the heat exchanger. Any equipment is only as good as the installation and proper setup when it is new. (3) You should NOT be smelling any gas in the house, period - unless you have a leak. You may be smelling carbon dioxide which is from burning fossil fuels - escaping from the crack in the heat exchanger. (4) What happened to the "Warranty" ?. Before you blow yourself up, Don't try to light the pilot anymore. Call a legitimate contractor.
Mar 29, 2017 | Heating & Cooling
Ideal boiler no heat to radiators but hot water still working
check the divertor head and valve.
sounds like it ist adjusing from dhw to ch.
take head off(remove pi at back,or side pin) and push pin in valve when calling for ch,if it works then the head has gone.
Nov 19, 2009 | Honeywell Programmable Thermostat Heater
Blank display on ideal isar 2 he 30
may just be a defective display PCB, byt more often than not, its the more expensive main primary PCB. Ideal actualy modified this PCB, and has a pre-fix of VF on it, and is orange in colour
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Jan 16, 2009 | Water Heaters
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
