I have to keep resetting my reset button after i use the hot water
    Problem Solver:
  • 5 Answers
Power overload.. switch to another outlet or use a power strip with a fault light
Posted on Apr 07, 2011
Why does the reset button on one of the tanks keep kicking when no water is being used?
The tank is overheating when not in use. If it is an electric water heater, you must replace the upper and lower thermostats as well as the high limit(reset button). If the tank is 10 years old or more, you may want to replace it rather than fix it as the average life of a tank is about 10 years before it starts leaking.
Mar 03, 2016 | Water Water Heaters
Electric wh high temp shut off button keeps resetting
Water heater has upper and lower elements. Only one t-stat. Check to see where tstat is set to. Turn down to lowest level. If breaker still resets then replace tstat. It is letting the water get to hot no matter what setting it's on. So water is getting so hot that it trips breaker.
Dec 28, 2012 | Water Heaters
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
Aug 23, 2012 | Water Heaters
Hot water heater reset button
the water heater has a bad element. please donot keep reseting, as the could lead to an electrical shock.
Mar 15, 2012 | Rheem Water Heaters
Limited hot water from 62 gal ge model D03666 looking for type and how to replace heating elements
Open following links to get started.
If water heater has NO hot water, then best suspect is ECO reset button tripped on upper thermostat. Open upper cover and push in red reset button. If reset keeps tripping, I usually replace both upper and lower thermostat.
If water heater has some hot water, then upper element is good so test lower element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | General Electric GE SmartWater Household...
I have an AO Smith Model EES 52 917 hot water heater. This morning my hot water suddenly disappeared. I have tried resetting the breaker with no luck.. I am not sure what else to try.
You have electric water heater.
Inside the upper panel on water heater is a thermostat with red reset button.
1) Click the reset.
2) Put insulation back over thermostat so it is not exposed to cooler air, so it reads correct temperature.
After resetting thermostat, you will have hot water.
The reset automatically clicks off when thermostat detects temperatures in excess of 150 degrees.
The re-set is a safety device, and it keeps everything safe.
If reset will not 're-set' with cold water in the tank, then thermostat is bad, replace thermostat.
You can repair electric water heater yourself following steps on links below
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If the reset clicks off again, just reset it
This is not a dangerous situation
Reset thermostat as many times as necessary until you can fix the problem
If you have trouble fixing the problem, add a comment at bottom of this page and it sends me an e-mail and I will help further
Thermostats with ECO red reset
Oct 26, 2010 | Water Heaters
Lose of hot water at times
If you keep kicking the reset you have a thermostat that is bad...it could be either the top or the bottom one...but you will have the check and see if it is switching to the bottom element or not...if it does switch to the bottom it is the bottom t-stat bad, if not then the top one is bad...
heatman101
Apr 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Lochinvar electric hot water heater reset button
Is this a two element 220 Volt heater? Do you know how old the elements are?
I have a feeling your elements need to be replaced.
What are your thoughts on my remarks?
Dec 21, 2009 | Cell Phones
Electric hot water heater keeps throwing reset button
You most likely need to replace your thermostat. If your thermostat isn't cutting the supply to the element at the preset temperature, as it is meant to, the unit will keep on heating until the over-temperature cut-out operates. This is what the "reset button" is resetting. You should get an electrician or qualified service bloke to replace it so you dont go hurting yourself.
Mar 03, 2009 | Water Heaters
I bought a 19 gal. hot water heater in March of 2008. Model EIF20USO15V. Product #0800130. It worked for 3 or 4 months and then stopped producing hot water. I pushed the reset button once and it works...
My initial thought is the thermal protector reset has had it last reset. the question is why does it keep tripping? you may have other problems.
Unplug or turn the power off. make a wiring diagram of how the wires go where. tag them with masking tape if you have to.
Now remove the reset and take it to your local Hardware store. they should have a compariable replacement, if not maybe they can recommend a plumber who would have it.
Best of Luck!
Jul 09, 2008 | Whirlpool Washing Machines
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
