Question about First Alert Brk / First Alert Smoke Detector Alarm Battery Powered
Two first alert smoke detectors go off for no reason. All are on 110 with good batteries. Have had these for approx. 12 years with no problems until now when 2 of the 7 have gone off many times in the last week. Maybe they are feeling there age at the same time and becoming overly sensitive. Thanks
    Problem Solver:
  • 7 Answers
There may be dust built up in the sensing chamber. This can cause alarms to go off for no reason. Try vacuuming the alarm off particularly around the sensor if the cover is removable. These alarms should be replaced however, as they are more than 10 years old.
Posted on Apr 15, 2011
Green light flashing on first alert smoke detector
Remove the covers and give good clean with coton and meths sensors and covers and resit the alarm good luck.
Feb 06, 2017 | Home
Smoke detector removed from ceiling. Only wires visible, but I still hear chirping.
Look at the detector you removed, and all others that may still be wired in.
They all have battery backup. Although the detectors are hardwired, the chirping is coming from one of the detectors to let you know to change the battery.
Oct 06, 2014 | Home
I have replaced the batteries to the smoke detectors and they keep beeping. What is the problem?
It is possible that the battery is not contacting the metal clips inside. See if the can be adjusted out. More likely the detector is not recognizing the voltage of the new battery. You can try removing the detector from the ac power install the battery and reconnecting it to the ac. It should correct the issue.
Sep 16, 2014 | First Alert SA302 Dual System Smoke...
Fire alarm beeping after battery change
you need a good quality fresh battery, cheap or old batteries are not strong enough
Jun 27, 2014 | First Alert Brk / First Alert Smoke...
I want to disable the remote sensor function on the first alert sa302. My tv remote keeps setting off my smoke detector
First you need to remove the battery, hold test button down while re-installing battery, when detector beeps,it disarms remote feature. Normal detector then. this should dissable the remote feature. this is a very common complaint. If for some reason it wont turn the remote off get a piece of tape to cover the sensor.
If your happy with this solution a vote for the thumb up would be greatly appreciated. Thanks for using Fix Ya
Jul 05, 2011 | First Alert SA302 Dual System Smoke...
I have just replaced 2 out of 3 hardwired smoke alarms with First Alert AC plus battery backup detectors. The old one is about 30 years old along with the two new ones. What happens is when I plug them all...
If they are all thirty years old, Id replace them all. You can try first by giving the old one a good cleaning. Get a can of air and thoroughly spray in and around the smoke. You can also remove the cover and use q tip in alcohol to clean it well. If that does not correct the problem, replace the last one.
Nov 21, 2010 | First Alert SA302 Dual System Smoke...
I could not get to battery compartment of the first alert smoke alarm. Please tell me how to replace with new battery.
Hold the entire smoke detector,turn it to the left or right,u will able to take the smoke detector out.The battery compartment is in the back.
Sep 09, 2010 | First Alert SA302 Dual System Smoke...
Every hour my detector beeps and the green lights flashing is it carbon nonoxide or smoke or battery??
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Apr 17, 2010 | First Alert SA302 Dual System Smoke...
First alert smoke and carbon monoxcide beeps periodically.
You need to give the exact model I bet you have a battery back up in the event power is lost during a fire. I bet the battery is bad.. We all have had devices that are brand new and the shipped batteries are no good.
Please rate my service  PJ
Dec 03, 2008 | First Alert SA302 Dual System Smoke...
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
First Alert Brk / First Alert Smoke Detector Alarm Battery Powered Logo
847 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
