Question about GE GSS20IEP Side by Side Refrigerator
Red glow (from defrost heater?) at bottom of rear panel in freezer
I saw a red glow at the bottom rear panel of freezer portion of GE side by side refrigerator. It was the sound of the water dripping and hitting the heat coil? that drew my attention..then I saw the red glow and felt the heat. Not knowing anything, I unplugged the refrigerator and removed all contents. Now what? Is this actually part of the auto defrost cycle that I just happened to witness for the first time, or is this an issue? 12 year old GE TPH21PR Profile if I read the number correctly.
  • mekjdk Aug 18, 2008
    Same thing tonight - not sure how old our refrigerator is but saw a red glowing light in the bottom of our freezer of our GE side by side...what is it???
  • Papjm7 Jan 08, 2009
    I opened my freezer and heard a sizzling sound in the back so I looked in the back and saw a red glowing light in the back by the rear panels. Is this normal and is it ok to leave it pluged in?
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Posted on Sep 10, 2008
  • 3 more comments
  • gina_brogan
    gina_brogan Jan 24, 2012
    Thanks so much for posting this... You solved our mystery..lol
  • gina_brogan
  • Christine Sep 13, 2012
    We smelt a burning smell and went in the freezer to investigate. There was a red glow in the bottome and water dripping.After reading this i have learned that this is the defrost process happening. But my question is....what is the burning smell?
  • court Jul 08, 2013
    ty!! i was worried my freeer was going to catch on fire lol. ty for the helpful info
  • serinastewar Apr 22, 2014
    after the defroft (red glow in bottom of fridge and water that has been leaking on and off for almost a year this time as said i seen the red glow and smelled the burning did not unplugg my fridge but in is warm now actually was getting hot so unplugged it today ..Should i just buy a new one or have someone out does anyone know ?Don't want to pay someone to tell me it's poched then buy another one.thanks.
SOURCE:
Our GE Americana A3309AASAWW has stopped cooling in the refrigerator portion...the freezer still works properly...what could be the problem
Hi, Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section . Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function . Hope this help in solving the problem....
Oct 31, 2010 | GE Americana 15.6 Cu. Ft. Top-Freezer...
My GE side by side refrigerator is only 6 years old and the freezer defrost wont cycle off and it does not get cold enough..what i have tried to fix it is unplug it and get all the frost off the wall of...
Most likely , the problem is a bad defrost heater , pt # WR51X10055 , but I would still suggest going thru the motions to make sure . The heater runs about $45.00 .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature
Sep 28, 2010 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ge side by side I have to keep defrosting the freezer every 2 months or so the temperature starts going up the fridge runs more often when we remove the back panel within the freezer it is built up with...
Do this when the refrig starts to warm up . Don't defrost before this test .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in bottom of freezer
The red glow you see is simply the defrost heater doing its job. When the refrigerator defrost control senses it is time to defrost the evaporator, it turns on a heater that in the dark, can glow brightly. This is perfectly normal.
May 12, 2010 | Frigidaire Gallery GLHS38EE Side by Side...
My ge side by side model gss25jfmc ww will start to freeze food in the cool side then it stops cooling in the freezer side. Ice will form on the back wall of the freezer. I haved thawed it out &...
I can tell you how to find the problem , but , it is a little work .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig. is about 4-5 years old and regrig side stop getting cold then the freezer followed suit-not getting cold. what should i do
Look inside the freezer on the back wall. If there is ice on the back wall the defrost heater and defrost thermostat are the usual suspects. They are both in the freezer behind the back panel.
Look for a deformed defrost thermostat. The glass heater will look burned. Both can be checked with a meter set for continuity. No continuity equals a bad part. Remove the wires from the parts before checking or a false reading will occur.
Nov 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top portion offreezer is warm bottom is cold
Sounds like the defrost heater is bad . Part number WR51X10055 . You will need to remove the 2 or 4 screws , holding the lower portion of the inside rear freezer panel . The heater , is attached to the bottom of the coils , held on by 2 screws . You should also replace the defrost thermostat , Part number WR50X10068 . This is the 1 " cylinder , clipped to the top of the coils , with a blue and pink wire attached to it . This bimetal (defrost thermostat) , cuts the heater off , when/if the temp behind the panel gets to 140 degrees , therefore , keeping the food from defrosting .
Oct 22, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Our freezer on our ge profile side by side is not staying cold
Pull the refrig out from the wall . Behind it you will see an 8 " X 10 " panel , held on by several screws . Unplug the refrig and remove the panel . On the control board , you will see a blue plug with 3 larger wires going to it . Unplug this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire with both ends stripped about 1/4 " . Insert one end into wire2 and the other into wire3 . Plug the refrig back in . Open the freezer door and , at the bottom of the rear panel , do you see a red glow ? If no glow after about 1 min , then the defrost heater is probably bad . To replace this , you would have to remove the rear freezer panel , and under the coils , will be a glass tube . This is the heater . If you do see the red glow , then either the board or the #4 and #5 thermistor are bad . Start with the thermistors . Small 1" white cylinder , with 2 white wires going to them . One is clipped on top of the freezer coils , and the other is at the bottom of the freezer panel , inserted into a holder . These thermistors , tell the board the temp of coils , and freezer .
Sep 19, 2009 | GE Refrigerators
Back wall freezes up on freezer side while fridge side is too warm. fridge temperature stays between 60 to 70 degrees
Is the freezer fan working ? If not , control board probably bad . Pull refrig out from wall and remove power . Remove the 8" X 10" panel and you will see the main control board . Remove the blue plug with 3 larger wires . The sequence is : wire1 , wire2 , space , wire3 . Using a short piece of wire with both ends stripped about 1/4 " , insert the wire into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom rear for a red glow ( may take a minute or so ) . If you see a red glow , the main control board is bad ( the board you unplugged the wires from ) . If no red glow , then disconnect power to fridge , remove the jumper , and reinstall the blue plug and the panel .
Remove the food from the freezer section and remove the rear freezer panel inside the freezer . There you will see a round 1 " disk , clipped on top of the coils .Pt # WR60X10068 Defrost thermostat . At the bottom of the coils , you will see a heater . Pt # WR51X10042 Defrost heater . Replace both of these as the heater gets hot , and cuts off by the bimetal . he heater only has a screw on each side attaching it to the coils , and the bimetal just clips on . Easily repairable .
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model TFX22ZPDAAA GE side by side
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
7,535 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
