Where do I insert in cartridges? I have opened the from cover and find nothing there. I have also lifted the top but don't see how to insert the cartridges there either.
  • luisarroyo Apr 07, 2011
    Could you be must specific with the model and the mark of the printer?
  • Wayne Mineard
    Wayne Mineard Apr 07, 2011
    Need to know what make and model printer you have.
    Problem Solver:
  • 6 Answers
What kind of printer do you have?
Posted on Apr 07, 2011
Don't see the printer cartridge on Dell 1110 printer
To replace the toner cartridge: 1. Open the front cover. 2. Pull the used toner cartridge out and lift it up and away from the printer. 3. Unpack a new toner cartridge. Hold the cartridge carefully and thoroughly shake it from side-to-side 5 or 6 times to distribute the toner. 4. Pull the tape to remove the protective paper. 5. Locate the cartridge slot inside the printer, one on each side. 6. Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until it snaps into place. 7. Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed, printing errors may occur.
Hope this helps! Best of luck!
Jun 21, 2011 | Dell 1110 Laser Printer
Tip
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
on Mar 31, 2010 | Office Equipment & Supplies
How do i take out old cartridges
Hello Cutiepoochie,
  1. Open the printer lid and wait for the carriage to move to the middle of the printer.
  2. When the carriage is idle and silent, lift the cartridge latch to the open position. Figure 3: Lift the cartridge latchc01635642.gif
  3. Slide the old cartridge out of its slot. Figure 4: Slide the old cartridge outc01635643.gif
  4. Insert the new cartridge into the slot at a slightly upward angle with the copper contacts facing down and toward the printer. Figure 5: Insert the new cartridgec01635644.gif
  5. Press firmly until the cartridge clicks into place.
  6. Push down on the cartridge latch until it snaps shut.
  7. Close the top cover. The product automatically prints a calibration page.
You can read further by clicking the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01635545&lc=en&dlc=en&cc=us&product=304431
Feb 17, 2011 | HP DeskJet 5150 InkJet Printer
How do i insert cadrige
Turn the orinter off and follow these steps:
1) Remove the top cover by opening the top of the printer
2) Pull the older tone cartrige out, taking care of noticing how it is inserted into the printer.
3) Insert the NEW cartridge
4) Close the printer cover
Mar 31, 2010 | Samsung ML 2010 Laser Printer
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
How do i change the black ink cartridge on a lexmark x2580 printer
With printer on and connected to computer do the following:
Open top cover.
Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
Wait for ink carriage for taking position in the middle of the printer rail.
Open cartridge top cover.
Pull cartridge toward yourself and snap it out.
Do the same in reverse order to fit new cartridge.
Remember to remove cello tape strip from new cartridge nozzle.
Do alignment procedure after replacement.
Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Cannon Phonefax L80
the cartridge isn't the problem normally when you close the front door there are switchs under the cover that control things like sensing the toner cartridge. most likly one of those switch levers are out of place. to check them your will have to remove the top cover to do this you will have to take the screws out in the back of the machine as well as the ones in the front covers when you have the door open. then the top cover will lift off and the lever and switchs are on the right side facing the front of the machine. with the top cover off you can close the door and see if the switch is being activated or if there is parts floating in the top of the machine. hope this helps.
Nov 15, 2007 | Canon FAXPHONE L80 Laser
Install Ink Cartridge
Swith on the printer. Open the printer top cover. It is called flap. Now press upwards the cartridge's top end. and lift up that. now take the cartridge out. insert the new cartridge the same way took the cartridge out. put the cartridge layer down. Now close top cover.
Oct 24, 2007 | Lexmark X1240 All-In-One InkJet Printer
108 people viewed this question
jasbo
jasbo
