Question about Rainbow E series Canister Wet/Dry Vacuum
Assembly Where can I find the assembly manual for the Rainbow E Series online?
Can't figure out how to hook up steam cleaner
Posted on Jan 24, 2009
Http://www.rainbowsystem.com/rainbowsystem/pdf/manuals/rainbow_eseries/eseries.pdf
Posted on Oct 01, 2008
  • 2,794 Answers
Looking for replacement component for motor controller board, a capacitor that is in series with the AC input line.
Unfortunately Rainbow does not offer this part by itself, they only make the computer as a complete assembly. Rainbow E2 controller 120v You can try contacting local vacuum shops and see if they have any broken Rainbows with good controllers that they would be willing to sell only that part to you.
800-775-6586
GoodVac com
Feb 10, 2015 | Rainbow Vacuums
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How do i reinsert the black little chip on my rainbow vaccum e2 so it can turn on
<p>The part that is sounds like you are talking about is the <a href="http://www.rainvac.com/interlock-plunger-e">Interlock Plunger.</a> This part is under the <a href="http://www.rainvac.com/baffle-plate-asm-right-e">Right Baffle Plate Assembly.</a> It works with the <a href="http://www.rainvac.com/switch-interlock-e">Interlock Switch</a> for safety so the Rainbow will not turn on unless it is latched onto the water pan. Remove the Right Baffle Assembly and insert into the small pocket that the Interlock Switch is installed.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Feb 02, 2013 | Rainbow E series Canister Wet/Dry Vacuum
When I turned on the vacuum it started to smell
the vacuum is either shorting or the motor or brush assembly is rubbing something.
Jul 31, 2009 | Rainbow Vacuums
Rainbow SE (1991)
little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
Mar 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E-series Aquamate II connection problem
Well I am not goinmg to call, but you can go to http://www.rainbowsystem.com/manuals/
And download the manual for your model of Rainbow.
Feb 28, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister shampooer
i have never used my rainbow shampooer and have had it 2 or 3 years it is not working it will **** up water but will not spray water or shampoo what do i do?
Feb 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer
aqua mates have an o-ringed valve assembly that go bad regularly reccoment having it replaced by local vac shop
Oct 07, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
464 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
