Question about GE Profile 24.7 cu. ft. Top Freezer No-Frost Refrigerator TBX25PABWW
The freezer seems cold however the refrigerator does not seem to be staying cold.
SOURCE: New Refrigerator Past Warantee Not staying cold
Thanks - according to the inside of the refrig - I do have a 5-year seal warrantee and a 1 year refrig warrantee - thanks for the tip. No noise coming from freezer or refrig.
Posted on Nov 26, 2007
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
  • 833 Answers
SOURCE: pink fluid under refrigerator
Loklok...no, I don't think so. The only fluid in refrigerators is an oil which is sealed in the cooling system and we know you are cooling. Your fridge may need a full defrost. This occurs because you may have left items uncovered and the moisture condensed in the cooling coils. It could also be the result of improperly sealing doors caused by dirt/ bad gaskets or the like. Best thing to do: shut it off, open the doors and let it defrost fully for a day. Clean the condenser coils under the unit with a long brush. Dry out as best you can and restart. You'll likely be okay. Make sure your freezer side is at about 0-5 above...refrigerator side 35-45. Use a regular thermometer and leave the door closed for at least an hour. (Do these measurements a day after you've restarted.)
Posted on Jan 28, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
  • 15 Answers
SOURCE: freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
Posted on Jun 01, 2009
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
It sounds like your condenser coils need to be swapped.
Replacement parts are available from the manufacturer and aftermarket suppliers. More conveniently, you may be able to find replacement parts through the retailer that sold you the refrigerator or at an appliance parts store.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Refrigerators
The refrigerator section will not stay cold. The freezer section is fine. Nothing seemed to precipitate this recent change.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 17, 2011 | Amana Refrigerators
Just today the refrigerator part of our refrigerator has lost its ability to stay cold. The temp inside is 58 degrees. The freezer part seems find. any recommendations.
heatman101
Jul 03, 2011 | Refrigerators
My refrigerator isn't cold, but my freezer still works.
Put your unit on a 24 hr defrost the freezer coil is frozen and blocked with ice the fan cannot draw any chill from the freezer section.
May 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer is ok, but lower section does not stay cold even at max
I think it's a compressor problem, must be compressor air is low .
May 26, 2009 | GE Refrigerators
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Refridgerator Not Cooling
The coil was frozen on my unit as well. Guinco tech Ron announced that this was a bad system board. Seems to be resolving as of this writing.
Jan 02, 2008 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
