Question about Zyxel Computers & Internet
How do i setup remote management to my zyxel p793h from any computer. i want to be able to logon to the router from any location with internet, i belive this involves setting up a firewall rule
SOURCE: connecting using wireless
I don't believe Zyxel supports only Zyxel products. Finally, after analyzing the problem between the zyxel and the router, I found a solution that worked and allowed me to network both wired and wireless connections here at home. Set your router to auto-dhcp settings. Clone the MAC address of your computer. After this is done, put OFF first the router but make sure that the cable from the router WAN port is attached to the modem already. Then, put ON the zyxel and wait until it is fully functioning (2 lighted LED lights) before you switch ON the modem. Let both units (router and zyxel modem)synchronize first about a minute or so. Then connect/put ON your computers.
I found the above procedure to do it step by step so as to avoid conflict signals during synchronization which seems to be causing the non-internet connection.
Hope this helps!
Posted on Jun 17, 2008
SOURCE: setting up a zyxel router
somebody have the series number of,zyxel p330w,if somebody have,please send me by email,,,,el_travieso_insolito@hotmail.com thank you
Posted on Sep 27, 2008
frcs68
  • 1605 Answers
SOURCE: access home network remotely via zyxel modem
you will not be able to access from one network to another even if you are on the same workgroup. However, you can setup VPN on both side. the other is to use commercial remote software. i.e.: vnc, mypc, teamviewer, etc.... they don't need anything else, but do require setup on both machine. This is much easier, don't need any permission from the network administrator, or company permission.
Posted on Jan 09, 2009
  • 49 Answers
SOURCE: Router not recognized after all wired setup is complete
Remove the CD Setup,
>If you have the Internet connection on your modem.
>Unplug the Ethernet cable at the of your computer and place it at the of the router under the Internet port.
>You should have another Ethernet port, connect the other end of that Ethernet cable to the LAN port1 and the other end to your computer.
>Access the configuration page of the router by typing 192.168.0.1 on the address bar.
>On the login page. By default the Username is admin/Admin and leave the password blank and click ok.
>Once inside, click on Setup tab> then click Manual Setup
> Your connection type should be Dynamic DHCP IP
> Click on "Clone your PC Mac Address"
> Click on save settings
> Go Status and Under WAN check if you have values in the IP address. If you have value, then that mean you have an Internet connection by now. if you got all 0.. try calling your Dlink manufacturer to assist you on conneting your router to the Internet without running the CD or by doing it manually in short..
Posted on Jan 31, 2009
efs_perpends
  • 1996 Answers
SOURCE: Setup Issues
You might have to create a custom exception rule for Outlook.exe, but this can create compromises to your overall security.
Please see article here and here and here and here
Also be aware that 3com has a support forum online that may be of some assistance if you can't get it work.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 20, 2009
I am trying to configure my new NBG4115 3G router connexion, but when I try to connect to the Zyxel setup screen via http://192.168.1.1 the Tilgin home screen appears. My present router here in our home is...
Either your web-browser has "cached" the web-page previously delivered by the TILGIN,
or your computer is still connected to the TILGIN.
In the former case, "reload" the web-page.
In the latter case, turn off the TILGIN router, and try again to connect to the ZYXEL router.
Also, check that your network-cables are correctly connected to one of the LAN ports on the ZYXEL router.
May 12, 2011 | Zyxel NBG-415N Router
I forgor the Password of the router Model Number zyxel:p-6600hn-fl so could you please tell me
http://www.retrevo.com/support/Zyxel-P-660HW-D1-Wireless-Routers-manual/id/14715dj396/t/2/
Hi above is a link for your manual, download and it shows you in there.
Most often a hard reset will return the router to factory specs, and to logon with a browser you must then enter a login and password, usually they are admin and admin but differ from router to router.
If however you mean you WAP/WEP logon password, this is a different matter, again it requires a reset, and re-doing the internal WAP/WEP password setup again, this time noting down the "Key".
This too is all explained in the manual.
Apr 28, 2011 | Zyxel P660HW-D1 Router
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
I have zyxel nbg334w bought before xmas 08 can connect pc to internet with it but although wireless laptops and games consoles find it still wont connect i am connected to internet via virgin media...
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Jan 30, 2009 | Zyxel Prestige 334 Router
How do you access WPA Key Settings on a ZyXEL modem?
To access Zyxel configuration/setup utility, launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.1.1 (default IP address for most Zyxel wireless devices) in your Internet browser's Location/Address bar, and then press Enter on your keyboard.
If presented with a user authentication (login) screen, try the following:
Default Username - Zyxel Wireless Router: N/A (none, leave blank)
Default Password - Zyxel Wireless Router : 1234
If you cannot login using the above, verify that (a) you are entering your password correctly, and that (b) your CAPSLOCK key is off. It could also be due to the firmware (a set of instructions stored on an EEPROM microchip) on your Zyxel product being corrupt. If so, you would need to reset your Zyxel WiFi router to its factory default settings.
IMPORTANT: Do not forget to promptly secure your Zyxel router (using a strong password, a non-obvious WEP Key, etc.) following a reset to factory default settings. Failing to do so may potentially expose your entire WLAN to scammers.
*Your vote is highly appreciated. Thanks in advance.
Dec 27, 2008 | Zyxel P660HW-D1 Router
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
Router Not Working
First of all Reset by pressing a reset button or with the help of a pen. turn if off and restart ur computer Once you connect ur computer with router.. go to start-run- type ipconfig. if you are getting an ip address in range of 192.168.1.2 to 192.168.1.255, 1.Launch your web browser(IE). Enter ?192.168.1.1? as the web site address. 2.The default password (?1234?) in internet access setup choose "Encapsulation as ethernet and there should be nothing in username or password.incase you have been provided with username and password from ur ISP then enter those with ip address assignment setting as dynamic. See if you can open the routers settings page. once you open it follow the instructions given on this link in .PDF format to SETUP ur router for ur internet connection. http://us.zyxel.com/web/download2/P-334WT/quick_start_guide/P-334WT_1.pdf To learn about ur router n setup more visit: http://us.zyxel.com/web/download2/P-334WT/support_note/P-334WT_3.60.pdf I am also using the same router and i did the same thing with the help of *** support team. i got it fixed in just 15 minutes. u can contact them on *** Just try it out and let me know or call *** team. i am sure they will help you out. Cheers!!
Dec 14, 2006 | Zyxel P-334WT (P334WT) Firewall
Computers & Internet Logo
59 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
