Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
What is Model #795.79789.900 weight-as brand new --no food in it Elite trio??
  • 958 Answers
SOURCE: Kenmore Elite Trio 795
check the damper controller at the center of the fridge. this regulates the air that is coming from the freezer dependent on the signal from the thermistor of the fridge compartment. that is the other thing to check. check it for rresistance and it should change as you change the temperature of the sensor.
i hope i was able to help;;
Posted on Jun 25, 2008
  • 1122 Answers
SOURCE: kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Posted on Oct 01, 2008
  • 534 Answers
SOURCE: Kenmore Elite Trio not cooling
sounds to me as if the compressor is overheating and shutting itself down (the buzzing noise) Once a compressor overheats it throws itself into what is called thermal overload. There are several reasons that a compressor will do this. But you said you turned it off and back on and it worked for a while. If this is so then it is possible that your unit could be low on freon or the coils under the base of the fridge has a lot of debris on them. To clean the coils just purchase a coil brush from your local hardware store and using a flashlight to see, brush all of the debris off the coils. make sure to unplug the unit before doing this. If the coils are clean then you need to have the pressures check on your compressor to see if the proper level of freon is there. An appliance tech should be able to check this for you for a minimal cost. Good Luck
Dave
Posted on Jul 17, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 795 77244601
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
We have a 7 year old Kenmore Elite trio. The ice maker continues to make ice, but won't dispense it. It appears that the plastic ice shut off arm is stuck in the up position. How can I get it unstuck
Most arms on ice makers are metal.
You might have to take the food out of the freezer temporarily and put the food in an ice chest and disconnect the refrigerator and let it unfreeze the plastic arm.
Jun 14, 2017 | Kenmore Refrigerators
Elite Trio. What caused it to die suddenly after only six years?
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
CPSC Maytag Corporation Announce Recall of Kenmore Elite Brand TRIO Model...
Info on Recalled LG and Kenmore Elite Trio Three Door Refrigerators
Oct 01, 2015 | Kenmore Refrigerators
Food freezing in refrigerator
There has to be a balance between the freezer and the refrigerator because the refrigerator gets its cooling from the freezer, if you set the freezer to cold, the other side freezes,
Feb 17, 2014 | Kenmore Refrigerators
Cannot regulate the temperature and food and vegitables are starting to freeze.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 08, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore refrigerator#50562990 power on but fan not working and no sound at all,compresor not hot
I believe your model is the TRIO model, but the model number you listed will not come up. If yours is the model I think it is the Adaptive Defrost board inside the fresh food compartment is the most likely problem. Come back with the correct model number for example 596.73509 Elite Trio because some models had a few problem. At this moment I believe the ADC board part number 12566102 is the problem causing this. Let me know what you find,Thank You, Sea Breeze
Oct 14, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
2003 Elite trio won't get cold and just out of warranty
The FAN that sits on top of the condensor. Good thing is I had Sears protection plan. Bad thing is that the new fan was inferior quality and BROKE the next day. Called Sears again only to see that it was replaced with the SAME fan. Their replacement fan looks cheaply made with OPEN windings while the original had enclosed winding. Hope this helps!
Sep 22, 2008 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
