Question about Gateway Computers & Internet
My laptop won't turn on. What can I do? - Gateway Computers & Internet
    Scholar:
  • 142 Answers
Make sure you have a good connection with the power cord. Unplugging and plugging it back in will usually verify that. Check your power cable for any areas that are broken, has exposed wiring, or is very loose.
If there are any pins in the power connections make sure they are straight.
If is still does not start, take out the battery and try with just the power cord.
Do you get any lights at all anywhere? Do you hear any fans spinning?
Posted on Apr 07, 2011
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Battery won't Charge
Hope this helps
Nov 04, 2012 | HP Computers & Internet
I have pavilion dv7 won't turn on
First, To put the laptop to charge the battery for least 1 Hour, if continue won't Turn on , apply botton power and ESC and active the troubleshooting its possible that ypour battery is die,
Jun 21, 2012 | HP Computers & Internet
My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Feb 08, 2012 | ASUS Computers & Internet
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
