Question about HP Compaq nx9500 Notebook
I have nx9500. No power on response UNLESS 1.) battery is removed and 2.) on/off switch held down for 30+seconds and 3.) AC brick then plugged in. When all this is done and on/off switch pressed, the LEDs for power and volume with flick ONCE and the AC LED on front edge of laptop will light and stay on. BUT the second I touch the on/off switch, the AC LED dies instantly, with no ohter sound or ligh.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
It would appear from what you say, there is a short on the motherboard. This can cause the adapter to shut down, which it is suppose to do. Unless there is an object in the laptop, the motherboard is damaged and must be repair/replaced.
Please rate this solution.
Posted on Apr 07, 2011
We noticed today that the battery does not charge, nor will the laptop operate with only the power adapter connected. I've verified that the power brick is putting out the correct voltage. If I...
Check if the AC Adapter brick is getting warm when connected, if not then you need to replace the Adapter.
If AC Adapter brick is getting warm and still its not charging the Battery, please perform the following steps.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Note: With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
The procedure to remove this static charges from the notebook is known as power drain.
Performing a power drain procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
If issue persists, contact Notebook manufacturer for further support.
Oct 15, 2010 | Computers & Internet
Laptop shuting down and beeping
Forget about calling HP. Unless you recently purchased it, the warranty is already out. There's a known motherboard problem that HP will warranty ONLY if it's a few months old. Check their website or call if you have half a day to waste. Sorry for being negative, but in reality, there's not much hope.
Here's a "fun option" that has worked for some:
1. Power down the laptop.
2. Unplug the AC cord.
3. Remove the battery.
4. Plug the AC cord in again.
5. Push and hold the power on button for 30-40 seconds.
6. IF it boots up, install the battery and you're good to go.
They say this procedure removes static electricity. Actually, it's a sign of the motherboard going out. Days are numbered. Back up all data files when/if you can.
Sep 11, 2010 | HP Hewlett Packard Pavilion DV9000Z 17"...
HP STUCK IN HIBERNATION MODE. HOW DO YOU FIX?
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
or this:
1. Remove power supply and battery.
2. Hold power button down for 30 seconds.
3. WHILE STILL HOLDING DOWN POWER BUTTON, INSERT POWER SUPPLY, THEN INSERT THE BATTERY. *THE POWER BUTTON SHOULD BE HELD, THROUGHOUT THIS ENTIRE STEP.
4. At this point, the blue light and the charging light should both come on, and the computer should start properly.
And check ur operating system for errors by downloading reginout
Aug 16, 2010 | HP Pavilion dv6000z Notebook
Power comes on for a secound and then shuts off
Try this:
If not, contact HP or local service center. It is a hardware problem
Jul 26, 2010 | HP Mini 2140 Notebook
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
http://store.richspsxparts.com/ve12s.html
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
My mom can not turn on here laptop
Hi:
You might want to resubmit your problem, with more details, but some general things to check are:
1) Is the laptop battery charged, or is the laptop plugged in ?
2) Remove the battery, unplug the AC Adapter, then hold the power switch down for 10 seconds, then put the battery back in , connect the AC Adapter and see if it turns on
3) Remove the battery, unplug AC adapter, hold power button down for 10 seconds, and then plug in the AC adapter, see if it turns on.
If all of the above fails to help, You most likely need to take the laptop into a shop for further troubleshooting.
Oct 30, 2009 | Computers & Internet
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Jun 24, 2009 | E-Machines M5105 Notebook
I have my powercord plugged into my Dell Inspiron 1525 but the machine is not getting any power. I checked another powercord to see if it worked and it did not. How do I check to see if the machine had...
Check the AC adapter (the brick) if its showing light. If it does, try flexing the cable that is connected to your computer. Also, you may isolate the issue by removing the battery. If you can see light on your computer when you turn it on, it means its getting power.
Jun 14, 2009 | Dell F3534 Touchpad
Can't Turn Computer On
I understand that your Notebook is not turning on.
That's unfortunate.
However, try to perform the following steps.
= Power Drain =
4. Reconnect the AC adapter and Battery.
If the issue persists, I am afraid that you need to repair your Notebook.
Thanks
Aug 24, 2008 | HP Pavilion zd8000 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
HP Compaq nx9500 Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
