Question about Archos Android 5 MP3 Player
Why am getting jumpy pictures when I record from the tv and video.
I had the same problem, the only fix I could find was to press later when you dock the archos to the docking station so you view from the archos not the tv.
hope this solves the problem
Posted on Oct 22, 2012
Very jumpy video on pc when recording (not on TV) doesn't record smoothly
Make sure you have the adapter connected to a true USB 2.0 port, not a hub, or front panel USB connector. Check your CODECS also to see if thay are up to date.
Jul 12, 2010 | Roxio Easy VHS to DVD for PC
Recently whenever we try to watch a recorded item on our dvr or try and rewind a live segment the show acts very jumpy and then eventually freezes. Nothing we do can change the frozen picture changing...
Guest,
Are you still having problems with your DVR receiver? Try unplugging the receiver for 10 seconds and plugging back in. The receiver will reboot and acquire satellite signal. If this doesn't fix the problem there may be an issue with the receiver. I hope this helps.
Ray Calo
DISH Network
Jun 10, 2010 | DISH Network ViP722 DTV Receiver /...
RCA d56w20 changes aspect size and picture appears jumpy
Thats caused by the small signal board, which is actually a board known to fail when the aspect changes on its own like that. You can get replacement small signal boards at www.tvrepairworld.com
Mar 30, 2010 | RCA D56W20 56" Rear Projection Television
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Jumpy picture on tv from
YOU HAVE PUT ANY MAGNETIC PRODUCT NEAR UR TV.CHANGE IT'S POSITION
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami Fl.phone #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
Archos Android 5 MP3 Player Logo
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
