I have a Hewitt Package 42" tv, one day the picture just stopped working, we still had sound, but no picture (prior to that it would change channels by itself), i looked online and i ended up sending the YSUS board to Texas to get fixed, i got it back yesterday, installed it and it worked fine, until today, it went black again. Could it just have been a defaulty part on the YSUS board, or is there something wrong with the ZSUS board now?
    Novelist:
  • 159 Answers
If they " REPAIRED " the ysus board versus relacing it- then yes. It;'s some times called a domino effect. the "CIRCUIT BOARD " is "wave soldered " that means most " SURFACE MOUNT COMPONENTS " were " PLACED " by machine then soldered to board with a conveyer belt through molten solder. Over time these connections may weaken and " intermittently " open up. The process of being removed and shipped may have exascerbated any original issue. You can check for these defects with a magnifying glass or jewelers loupe. Any " LEAD "soldered through the board will be soldered on both sides-and will need to be checke for circular ring shaped cracks near the surface, cold solder joints at the surface mount level," PICK AND PLACE MANUFACTURING " may be checked for hairline cracks in silver " CIRCUIT TRACE " nearest the edge of the soldered " SURFACE MOUNTED COMPONENT " good luck. Prodzilla
Posted on Apr 07, 2011
  • nmastropieri Apr 08, 2011
    i checked yesterday and the picture isn't just black, there are little fashes of white now, i unpluged it for the night and this morning i pluged it back in and turned it on and the picture came on for a couple of seconds and then it went black again, is it still the YSUS board. What are the signs that the ZSUS board are bad?
I decided to try the TV again, after it sat for the day. I plugged it back in, turned it on from the tv panel. It came on picture and sound was fine. Within 10 minutes, everything stopped, went blue. I did...
sounds like it is over heating. in side the tv there is 2 square box cannot remember the colour but they are yellow or blue near to a heat sink chip. if you change them it may just be that fault. Bush tv's suffer from this problem.
Aug 31, 2013 | Spectroniq PLTV-42HW68 42 in. LCD TV
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
No picture on my philips 42PFL7422D/137 lcd I have already replaced both master and slave boards and my picture returned. After about a month or two the tv started to make a high pitch whistling sound...
do you have sound but no pix?its the video board if you have neither it will be the board where your coax and audio inputs connect...just a matter of getting the right boards off of e-bay GOD bless
Sep 18, 2017 | Philips 42PFL7422D 42 in. LCD TV
I have successfully connected my PC to the TV. But it only works in 1024x768 mode. Any other mode results in "invalid format". In the TV on menu selection under the picture sub menu the...
User manual: http://www.retrevo.com/support/LG-42LG30-TVs-manual/id/15220dj498/t/2/
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
See page 38~40 for what the TV can do when it is used for PC display.
From user manual:
37/42/47/52LG50, 32/37/42/47/52LG60,
32/42/47/52LG70, 42/47LGX, 47LG90,
50/60PG60, 50/60PG70: To get the the best
picture quality, adjust the PC graphics card to
1920x1080.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 15, 2011 | LG 42LG30 42 in. LCD HDTV
Viore tv sound but no picture
the sound suddenly stopped working on my Viore 42" plasma.
Aug 17, 2010 | Toymax Viore 42 in. Plasma TV
Shows no picture but has sound its a tedelex 42 inch
if you had no prior ideas about plazma tv . then call to some experienced person so that he can help you. oterwise take to the repair center .
Dec 07, 2009 | Philips 42HF7444T 42 in. Plasma TV
I bought a brand new 42 inch plasma vi vo tv 2
New products do fail. The set should certainly be under warranty. I would speak to the dealer you purchased the unit from and see what they suggest. Don't remove the rear cover, or do anything else to give anyone a reason to void your warranty. Most brands are 90 days on parts and labor.
Nov 25, 2009 | Televison & Video
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
LG 42'' PLASMA HD TV, NO PICTURE BUT SOUND WORKS
change the red wite and yallow wires around it shoud fix the problin
Jul 31, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
