Question about Keurig Elite B40 Coffee Maker
How do i empty the water from the internal tank in the coffee maker?
  • 66 Answers
Hi, I have attached a link to instructions and a diagram of all parts from the company. Please acknowledge if this is helpful.
Regards, Icom1
Posted on Apr 07, 2011
How do I empty the water from the main reservoir?
  • Turn off the Keurig coffee maker, and unplug the power cord. Allow the unit to cool for 30 minutes before emptying the water. This gives the water inside the hot water tank an opportunity to cool, helping to prevent accidental scalding when emptying.
  • Pull the lid off the top of the water reservoir. Lift the water reservoir straight up and to the right of the coffee maker. Pour out any remaining water in the reservoir into the sink.
  • Turn the small thumb screw on the back of the Keurig coffee maker counterclockwise with your fingers, and pull off the rear access panel. If the screw is too tight to turn with your fingers, use a flat-head screwdriver to turn the screw. Once you remove the access panel, a tube with a plug on the end is visible. Pull the tube out of the plastic clip holder.
  • Place a large pitcher behind the coffee maker. Hold the end of the tube over the pitcher, and pull the plug out of the tube. Allow the water to drain into the pitcher. If necessary, maneuver the coffee maker to the edge of the counter, and hold the pitcher alongside the counter with the top at counter level.
  • Push the plug back into the end of the tube once no more water drains from the hot water tank. Empty the pitcher of water into the sink, and push the tube back into the plastic clip holder. Position the back access panel onto the coffee maker and secure with the thumb screw knob.
  • How to Empty the Water Reservoir on Keurig Coffee Maker eHow
    Apr 08, 2015 | Keurig B60 Coffee Maker
    Barista supremo thinks it doesn't have coffee beans
    http://www.espressotec.com/media/downloads/57/SA1260_Odea_Giro_plus_manual.pdf The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
    Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
    SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
    Hello.
    1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
    2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
    3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
    4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
    Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
    Thanks.
    Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
    How empty inner water tank
    You must first empty the water reservoir. There is a black disk inside the tank. This disk moves up and down. Place your hand inside the tank and hold the disk up. This will stimulate the tank being "full" of water. Then continue on as if you were brewing a cup of coffee. This will brew the remaining water left in your inner tank. May need to do this twice to ensure all the water is gone. Hope this was helpful.
    Jun 22, 2010 | Keurig Platinum B70 Coffee Maker
    Saeco Coffee machine water tank empty
    It is possible that the water sensor on the back panel of the machine is not operating, you will have to remove the back panel and check the sensor with an ohmsmeter.
    May 18, 2009 | Saeco Royal Digital Plus Coffee...
    3-Pot coffee Maker instructions
    The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
    Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
    After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
    Jan 25, 2008 | Bloomfield 8571 Coffee Maker
    Water does not get to main compartment
    try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
    Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
    Coffeemaker
    The Bunn coffee machine has an internal tank used for holding approx three potfulls of water at just below brewing temperature. When you add water for a potful, the thermostat senses cold water and starts the brew heater. The water level inside the tank comes up and goes through the sprayhead. This "surge" of water, that you call drips is normal. The hot water stratifies to the top of the tank, just like an electric water tank in a house. The internal pot heater kicks in and boils the water already in the tank, raising the water level in the siphon pipe to the sprayhead until the reservoir under the add water opening is empty.
    Sep 15, 2007 | Bunn NHB Coffee Maker
    Keurig Elite B40 Coffee Maker Logo
    793 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
