Question about Panasonic KX-TG1100 Cordless Phone
I have two pairs of panasonice codless phones and a couple of them no longer seem to be paired with the base. How to do I solve this?
Deregister your handset by dialing *331734# then selecting the Menu/Select button. Phone should ask you to place in base to register. Wait a few moments and you should be able to user your handset.
Posted on Sep 30, 2011
Pairing rejected problem?
Make your device visible for a longer time so that you can enter the pairing PIN.
Sep 28, 2014 | Radio Communications
Tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 | Cell Phones
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Feb 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
When I try to couple the BH-218 to my Garmin i press the ]as in the manual but only get voive prompt on or off, the coupling mode does not seem to function.
My guess is you don't have the headset in pairing mode. The instructions below are from the instructions for the BH-218"
Before using the headset, you must pair and connect it to a compatible phone.
1. Make sure your headset is switched off and your compatible phone is on.
2. If you've never paired the headset with a device, or you've cleared the pairings,
switch the headset on.
If you've previously paired your headset with another device, press and hold the multifunction button
for 5 seconds.
Pairing mode is switched on, and a blue indicator light starts to flash quickly.
3. Within 3 minutes, switch Bluetooth on in your phone, then set it to search for
Bluetooth devices. For details, see the user guide of the phone.
4. On your phone, select the headset from the list of found devices.
5. If asked, type in the passcode 0000.
When the headset is connected to a phone, the Bluetooth indicator light flashes
slowly.
You can pair your headset with 8 phones, but you can only connect it to 2 phones at
the same time.
With some phones, you may need to make the connection separately after pairing.
Tip: Can't connect the headset to a compatible phone? Make sure that the headset
is charged, switched on, and paired with the phone.
Jul 15, 2013 | Nokia BH-218 Bluetooth Headset
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
I have an Explorer 210 series. It will no longer pair
Just this morning I was able to pair this headset with my phone. Before, it was paired to my PS3. The key is to hold down the big round button on the outside until the light flashes red/blue (this is quick-pair mode) then just have your cellphone search for bluetooth devices and you're done!
Oct 25, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Anyone successfully paired any phone
It seems to me that the more advanced the phone is, the less likely it is to pair correctly. My wife has an LG Vu and it pairs beautifully. Picks up every time. I have the Windows Mobile based LG Incite and it doesn't work too well at all. Also tried it with my friends iPhone. No luck there either.
So my solution would be to get a basic phone. Sorry :-(
Jun 27, 2009 | 2005 Land Rover Range Rover
Headset not working
Sounds like your headset isn't paired with its base. With the headset in the cradle press and hold the button on the left side of the base that has two arrows on it. You should see the blue light on your headset turn on. Its now paired to the base.
If that doesn't work, remove the battery from the headset. (This is the back piece of the headset.) Wait a few seconds and then snap it back on to your headset.
Good luck.
Dec 07, 2007 | GN Netcom GN 9330 Wireless Headset
Base set fine - additional handsets dont work
The additional handset and the base need to "pair" first. Put the handset in the base cradle till you see the red light blinking. That's when they are paired.
Nov 07, 2007 | GE 25951EE2 Phone
Panasonic KX-TG1100 Cordless Phone Logo
137 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
