Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer When the spin cycle starts it makes a horrible noise and doesnt spin. Any idea what my problems is?
  • 943 Answers
HI thanks for your question. YOUR problemis with what is called a drive coupling. This part is located between the motor and transmission . so if this breaks it stops driving the transmission Thanks for the question .THE appliance doc
Posted on Sep 11, 2008
SOURCE:
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Dec 26, 2008 | Danby DWM5500W Front Load Washer
Kenmore 90 series
These are typical symptoms of a broken motor coupling. Believe it or not, this is a common problem and very inexpensive to repair (about $15 or less). If you wish to tackle this job on your own, the following link gives you step-by-step instructions:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The link also gives you the part number and which website you can order it from. If you do not wish to order on line, use the part number provided and go to your nearest appliance parts retailer. This is a common part that most retailers carry. I would recommend a Sears parts store or Whirlpool (your washer is manufactured by Whirlpool). Let me know if you require additional assistance. I hope this helps you.
Aug 28, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
53 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
