Question about Weber Summit Gold D6 (NG) Grill
How do I remove burner tubes on summit gold - Weber Summit Gold D6 (NG) Grill
    Brigadier General:
  • 4,736 Answers
The burner ends (the tips farthest from you) are either held in place with a sheet metal screw or the tip fits it a small slot. Either way, removing the burners is the same. If it has a sheet metal screw - remove the screw and lift the burner up and toward the back of the grill. While lifting the burner, pull if away from the front of the grill, so that it slides off the the venturi valve and the burner will lift out.
That's about all there is to it. To help you further, I have included a link to your Owners Manual, that you can download and print for future reference.
http://www.weber.com/help/manuals/pdf_files/Summit_Gold_D_NG_41996_03_27_03_Revised.pdf
Happy Grilling!!
Posted on Apr 07, 2011
How do I light the rotisserie infrared burner?
Nice unit. I was looking at it last night in Home Depot.
http://www.weber.com/grills/series/summit/summit-s-470
Should spark ignite like the burners surely? Perhaps the igniter post needs adjusting, or a lead has become disconnected?
Aug 12, 2015 | Weber Summit S-470 Liquid Propane Grill -...
We have the Summit 675 NG built in grill that is several years old. The igniters and crossover tubes have totally eroded. Can we just manually light the grill with no additional problems or do these...
Yes, you probably could for a while. But, the rust and corrosion is going to spread to the other burners eventually.So, it would be better to replace, what's needed. The parts are available directly from Weber
http://store.weber.com/parts/gas/ Or from Appliance Factory Parts
http://www.appliancefactoryparts.com/
The parts you need are not expensive and are fairly easy to install.
Hope this helped you. Please let me know and Happy Grilling!!
May 25, 2011 | Weber Summit 675 Stainless Steel Grill
Summit 670S Natural Gas - Takes several attempts to ignite each burner. Even after holding each knob in the on gas flow position for several seconds to allow for the proper gas air mixture to take place.
Pipe Guy, You need to remove the burners and clean them throughly and the venturi valve on each burner. Spiders love to build nest in them. That should correct the gas to air ratio.
May 03, 2011 | Weber Summit S-670 Gas Grill
How do i change the burner tubes on the weber summit
It's fairly easy to do (unlike Ducane Grills). To help you, I have included a link to your Owners Manual, which will really help you. Go to the Maintenance section, Page E-1 for the drawings and description of how to remove the burners.
http://help.weber.com/manuals/pdf_files_2011/Gas/Summit%20SilverGoldPlatinum/OwnersGuides/Summit_SilverGoldB_LP_OwnersGuide_43720_012903.pdf
Hope this helps you to "Get 'er done!"
Happy Grilling!!
May 01, 2011 | Weber Summit Silver B Grill
I have weber q200 grill and only 2/3rds of the burner will light. what is causing this?
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 08, 2010 | Weber Q Grill
The grill will not light
It may be the regulator replace that and you should be ready to go!
Jul 06, 2010 | Weber 2780001 Summit S-470 Gas Grill
Some holes are plugged on burners and i need to clean
I know on some grills you can use a tooth pick to clean out the tiny holes that are plugged.
Mar 15, 2009 | Weber Summit Silver B Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Jun 17, 2008 | Weber Genesis Gold B Grill
Weber Summit Gold D6 (NG) Grill Logo
529 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
