Question about Car Audio & Video
Wont take in cd, when i push it in it will play but it wont eject
  • 4 more comments
  • RamonC Apr 07, 2011
    already have unit out of car, this does not work. pushed in reset also no change.
    clarion DXZ865MP
  • RamonC Apr 08, 2011
    I already opened it up . this is how I removed the CD from the unit. When I try to push it back in, I hear the assist motor trying to take the CD in, but nothing happens. When I force it back in all the way, it engauges and plays. I need to know if this mechanism is gear or belt driven and what I have to remove to get to it and repair it. Thanks
  • RamonC Apr 09, 2011
    How do I get to those gears. what do I take apart to access them ?
    The advise I got from the other tech is something I already have done. There are many screws and I would like to know which ones to remove so as not to over do my disassembly. I juut want to get at the CD insert assist drive to replace what ever is broken.
  • RamonC Apr 10, 2011
    If it is the belt what is the easist way to access it . I already have the unit open and i can not see it
    THANK YOU
    Top Expert:
  • Car Audio & ... Master
  • 74,666 Answers
Hello
Either your indash CD players' loading motor or its loading belt is faulty. During long run it is common to be the belt get loose. Just try by replacing the belt first. In most cases the fault should be retifed. If not, check the pulling power of loading motor. To access it, you have to open your CD player, and get it power supply to an external supply adapter. When a disc is inserted, it will draw in, by the help of loading motor and its associated gear wheels. If you catch the pully of that loading motor, when it attempts to take a CD in. there will be a force for its rotation, and we can feel to our fingers.. It won't allow us to put it to stop, that much force will be there, and should be. If the force of rotation of the loading motor pullye is less, replace the motor with same type and number. The problem to your CD player is purely mechanical, and not for an electical or control circuit. If you want anymore assitance feel free to get me by Fixya. OK.
Posted on Apr 09, 2011
  • The Knight
    The Knight Apr 10, 2011
    Hello
    This type of mechanisms are motor, gear wheels, and liver engaging types. Tese can be damged very easly, and the complaint rate to these types are high. now your players' functions, all except the mechanism, is working fine. in these type of mechanisms. if the livers that pulls discs in and out may get a slight bend or worn out, they wont work properly, and it will be very difficult to get the spare livers or gear wheels, or even its loading motor. So I advice you to replace the damaged mechanism with a new one, rather than making adjustments to it, or making a 'sugery' over it. During repair, if something happens to touch whic its other circuit parts, and gets shorted, the present condition of the circuit board also will go out, and the set may get irreparable.
    These type machanisms are easly available in electronc sparepart shops, and not cost too much. 'New one is New, and repaired one is Repaired". Isn't it? Get the mechanism out of the set, without making andy damge to its strip wires and other connections from the main board and to, keep this mechanism as a sample with you, and go for a new one. Reset the player. it will be good for you rather than destroying the other components too. OK.
  • 17,970 Answers
First fashion to try here is rebooting the system. You can do this by disconnecting the vehicles battery for several minutes.
Send us details about your brand and model device.
Posted on Apr 07, 2011
  • ZJ Limited
    ZJ Limited Apr 07, 2011
    The unit needs to be taken apart. Something is probably jammed with the
    eject mechanism, or the tolerances are higher than they should be with
    the rest of the moving parts.
    Good luck.
  • ZJ Limited
    Only if you are out warranty, and if you're feeling ballsy, you can take it apart yourself with some small screwdrivers (and sometimes torx). The problem with trying to use tweezers, is that if the the disc lock is engaged, you can't pull it out, unless you open the deck up.
    President:
  • 1,961 Answers
Yes youre right sir there is an assist motor there is an assist motor that activates by the CD in sensor in your case examine the assist motor mechanism.There might be a problem on the gears causing the mechanism fails to take the CD in.You need to re align the mechanical and be very careful when dis assembling the mechanism.There is a timing on mechanical movement of every gears and mechanism so you need to arrange them to the right gear timing...good luck!
Posted on Apr 08, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Apr 09, 2011
    open the top cover of your player and you can see the mechanism remove the parts one by one so you will not be confused with the placement of every parts.just like I told you before you can consult a skilled technician to do the job.
4 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
nuwan chinth
  • 111 Answers
SOURCE: LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Posted on Jan 09, 2009
drsinister69
  • 2317 Answers
SOURCE: stuck cd
Behind the faceplate there should be a reset button, you can try pushing that button to see if it'll eject the CD.
Posted on May 07, 2010
How do i get a stuck cd out?
hold your finger on eject button then turn power on, your finger must stay pushed on eject switch too work
Sep 06, 2014 | 2005 Pontiac G6
2006 Grand Vitara 6-Changer CD Player will not eject cds. 'Push Eject' error comes on.
this is a longshot, try unplugging it, wait about 30 seconds and plug it back in.
Sep 17, 2012 | 2006 Suzuki Grand Vitara
Can't get my cd to eject from car stereo
Did somebody put coins or something inside it? Try putting a high power vacume up to it and seal the whole opening with the vacume end...
Jun 18, 2012 | 2006 Chevrolet Malibu
Stuck cd
press & hold the eject button
Feb 07, 2009 | Alpine CDA-7863 CD Player
nuwan
Jan 08, 2009 | Car Audio & Video
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
DRIVE UNIT WONT OPEN OR EJECT
You can eject the cd by pushing a paper clip into the small hole in the draw.
Sep 26, 2007 | Acer Aspire 5100 Notebook
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
