Question about York Barbell Home Use Fold-Up Treadmill
I have a york inspiration treadmill and I am getting error code 2 - motor connection error. I have checked all the connections. Could this be a faulty motor?
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
  • 3 Answers
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Posted on Feb 03, 2010
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
York treadmill t-801la T780 platinum error code 1
see the comentary ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.7099b61f-975c-463c-9361-522952e1c927.gif
Run the software calibration for easy diagnostic and fix it. God bless you
Jul 08, 2013 | Exercise & Fitness
York treadmill T780 error code 04
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The
mark of the DC motor and control board should be matched connected. Sometimes you also check the wires of motor, and restart the machine complete.see the diagram attached
Jan 22, 2013 | Exercise & Fitness
How do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
Jul 12, 2012 | Exercise & Fitness
I have a York Fitness Inspiration treadmill that won't work - nothing on the control panel, no signs of life except a very quiet hum that proves power is going into it - have tried changing the fu
Dear Sir:
Please adjust the reed swtich , attached below see the diagram and adjust according. 1/8-/14" 2) Tight the ribbon cable from keypanel 3) Tight the connecto from display board vs main motor board.
Run the software calibration for easy diagnose and troubleshooting.
see my block diagram for better understanting.I fyou want to measure the motor see my personal TIPS. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 17, 2012 | York Exercise & Fitness
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
hi,
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
OK
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
I have a York evolution tv treadmill model x8 which starts for about 3 seconds then stops with E7 on the display, I understand this is a safety key error code but the key is in place and if it's...
Definition: Incline motor calibration abnormality: 35~40 seconds after the down command was sent,
the calibration base signal was not received.
Check the calibration motor (mechanical +electrical)
Jul 11, 2011 | York Barbell Home Use Fold-Up Treadmill
Where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Apr 11, 2010 | York Barbell Home Use Fold-Up Treadmill
York Barbell  Home Use Fold-Up Treadmill Logo
449 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
