Question about Hayward SAND FILTER, PRO SERIES
Sand filter decal is curling from sun and will soon be unreadable. Can I buy a replacement decal to stick on the unit other than buying an entire new valve head? Also the handle on my sand pump is very hard to move around can I use something like WD40 on it to help with that?
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: sand filter problem
The pump is to big for the pool. So with that being said it is asking you to back wash more then you should need to because it is pulling water at a much higher rate then what your pool is actually calling for. I would recommend taking it down to a 700gl and this would solve your problem. Also you can replace the drain lines and suction lines to smaller lines and that will also take care of the issue at hand but I do not recommend that at all
Posted on May 27, 2009
SOURCE: hairline fracture s200 hayward sand filter
Here's a link with a fiberglass repair procedure:
http://www.ehow.com/how_2060134_repair-crack-fiberglass.html
Is this what you need? If not, let me know...
Charlie
Posted on May 29, 2009
  • 6 Answers
SOURCE: Sand from the filter is getting into the pool.
u are getting sand in to your pool most likely because u have a broken lateral i nthe bottom of your filter.
Posted on Jun 09, 2009
john224
  • 1378 Answers
SOURCE: Control Valve handle wont stay in position
The valve should be about $100. We sell it for 90 something. You can rebuild them with gaskets and the spring. There should be a model number on yours, care to post it? Something like SP711, SP714, etc.
www.arrowmotor.net
Posted on Jun 14, 2009
Can a Hayward s 166 t Hi rate sand filter be rebuilt
Parts can be replaced sure, but will it be worth it compared to buying a replacement or even upgrading. Laterals (if broken sand gets in pool) can be replaced on this unit from 48 off amazon and is cheaper than buying a new unit, same with leaking rings or seals. but if a part of the tank is cracked or something like that you might up spending almost as much to replace a piece of the unit as it would be buy a whole new unit. Amazon has this model for 180$ if repairs would cost more than 80 I would say replace it, these things dont last forever, especially if you live in a cold place that freezes in the winter and it sits in the sun all summer.
Hayward S166T Pro Series 16 Inch Top Mount Pool Sand Filter Hayward SX164DA Lateral Assembly with Center Pipe Replacement for Hayward...
Hayward SP0714T Pro Series Vari Flo Top Mount Control Valve
Hayward SX164AA1 16 Inch Filter Body with Skirt Replacement for Select...
There was also a couple smaller parts on amazon but you should check it out and also compare them to some other places.
Aug 09, 2015 | Hayward Pool & Spa
Why does intex filter pump warm water into pool?
im not aware of this unit having a heater on it if your saying that running the filter raises the temp in pool , ck to see if the pump is facing south east , if so move entire pool to a NW side , or add some sort of sun shade to pump
Jul 07, 2014 | INTEX Sand Filter Pump
HOW TO HOOK SANDFILTER UP
out of the pump to in of the sand filter out of the sand filter to in of the pool
Jun 07, 2014 | Intex 2500 Gallon Sand N Sun Pool...
Symbols around dial of electric cooker have been rubbed out. Can I purchase new stick on ones?
Well, they don't sell stickers anymore but u could buy graffix art stickers numbers that are in different sizes and u could do it by urself!
When sticking those numbers, try to buy the CLEAR COAT paste spray, use by artist and architects, spray it on those stickers to have them laminated for life! Hope that helps u out!
Nov 18, 2010 | Ovens
How do I change the sand in my Hayward S220t Top Mount Pro Series Sand Filter
un-screw the entire top valve unit. I would duct tape over the top of the riser pipe at the top.You do not want to get any sand inside that pipe. Turn upside downand rinse out completely. Add new sand remove duct tape and replace top valve unit
Jun 12, 2010 | Hayward S220t Top Mount Pro Series Sand...
USB stick is lost.
was a new usb stiock found? same problem
Jul 01, 2009 | Microsoft Presenter 3000 Mouse
Sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Jun 17, 2009 | Hayward Pro Series 18" Above Ground Pool...
2000 Volvo S70 GLT SE
You must drain the tank remove from the car flush it out with pump and screen out of it you will need
a list or car jack and several stands change the screen and fuel filter also . Good luck
Mar 09, 2009 | 2000 Volvo S70
Dropped fe- 230 camera in sand..spazzing out..help ASAP please
Borrow a friends camera or buy another.
The motorized lens assembly is contaminated, and
your only recourse is to replace the entire assembly.
It has very close tolerances and even replacing it is no guarantee that all the sand particles could be cleaned out of the camera body.
Sorry. No easy fix this time.
Regards Paul
May 30, 2008 | Olympus FE-230 Digital Camera
Hayward SAND FILTER, PRO SERIES Logo
255 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
