Question about Logitech X-530 Computer Speakers
We just had our system updated to Windows 7 and for some reason even though the speakers are plugged in and switched on I'm getting an error message stating that they are not plugged in. Is there any software I need to load up perhaps? Can't find the problem.
  • Logitech Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps or you could download
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Update your embedded sound from Realtek to the latest AC'97 codec.
Hope this helps
Posted on Apr 07, 2011
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
No sound on PC, from external speakers - please help! :)
first thing you do is update your audio card or down load a software like(.driver identifier.) its free from google you will see an instruction to opereate that software
Feb 17, 2014 | Computers & Internet
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
Nov 06, 2013 | Microsoft Windows 7 Home Premium for PC
Hi, I cant get the usb ports for speaker or mike to work I have an aspire m1800 desktop win7. when i try to do anything I get message that im using a vista only driver but when i try update driver It...
Try googling windows 7 drivers for the name of your sound card
You can find the name of it, in "device manager", under "properties" of "my computer"
Usually though vista drivers work with windows 7
Or you can open windows update, and see if there is any "optional" updates
There might be listed a sound driver for your windows 7
Another option is download "Driver Genius" free version
Lets you see what drivers you need, however you need to pay to actually download the drivers
You can just copy the name of the driver and google it yourself
Goodluck
Apr 05, 2011 | Acer Computers & Internet
Each time I plug in the USB cable I get a blue screen. I am running Windows 7. I am trying to load maps onto the Triton 400.
Don't bother with the 400 on a Win7 machine even though Magellan claims it will work. I also keep getting a bad pool header blue screen on mine even though I've updated everything I could. The best thing to do is to either setup a dual boot system with WinXP and only plug it in while running XP (Don't bother with XP mode in Win7) or have a second system that's dedicated to XP and run Vantage point from it like what I run now from my laptop.
The whole problem is caused by the Triton driver and for some reason Win7 doesn't like it all that much. Vantage Point does run great inside Win7 but as soon as you plug in the Triton, that's when it all starts to screw up.
All we can do is wait until Magellan gives us a proper working driver.
Aug 21, 2010 | Magellan Triton 400 Handheld GPS Receiver
I have upgradded my Laptop operating system to
Use the ones for Windows Vista. Vista Drivers work for 7.
Now considering these speakers plug in via headphone jack you dont need drivers for your speakers. You should be looking for sound drivers for your laptop.
Plug in headphones see if they work if they do then there is no reason why your speakers should not.
Apr 25, 2010 | Logitech Z-2300 Computer Speakers
Connection Error Message
I believe that you maybe using windows Vista or Windows 7 for which the webcam is not compatible with these operating system, check the manufactures website to see if there are any updated drivers to support the operating system.
Jan 27, 2010 | GE EasyCam Webcam
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
Nov 09, 2009 | Microsoft Outlook with Business Contact...
Logitech X-530 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
