Question about HHP IT3800 Handheld
I have a Follett 3800 scanner...it beeps when I click on a barcode, but doesn't record the information.
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
SOURCE: the scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Posted on Jul 06, 2007
SOURCE: it3800 barcode scanner problems
Will it scan data into excel or word?
Posted on Aug 05, 2008
SOURCE: The scanner is scanning but no data is transmitted to the PC
I also purchased a Symbol LS4071 and when I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector - the connector is split like a "Y") I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
Follett dolphin phd
So, I had a large scan.log file which I would have lost if I followed the instructions above. Instead hold the shift, on scan and bksp buttons simultaneously. The device will reboot with your file still functional!
Aug 27, 2013 | Computers & Internet
Tip
How do I Register a Barcode scanner
<p>In general, all manufacturers provide information on the registration of their products. By registering your barcode scanner, allows easy access to guarantees, technical support and maintenance and notification of product announcements, updates and offers. The record provides a record in case you need a replacement due to theft or damage. In return, the company your personal information to send you announcements and discounts on your scanner and other products they sell. <br /> <p><br /> <p>1. Go to the manufacturer's website. Determine if the barcode scanner to register online or to install the necessary drivers and the registration process. If not, connect the barcode scanner to your computer via the USB cable. <br /> <p><br /> <p>2. Turn the scanner installation CD into your CD-ROM. Please wait while your computer loads the driver installation wizard. Follow the wizard and install the software. A window will open asking if you want the scanner to register. Select "Yes" and wait while your web browser opens to the registration website. <br /> <p><br /> <p>3. Enter the information requested on the on-line application. The typical form requires your name, e-mail, model and serial number of the scanner. Also, some require a product key or registration. <br /> <p><br /> <p>4. Click the Send button to send your information and complete the registration process. <br />
on Jun 26, 2011 | Computers & Internet
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one? http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
Feb 07, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
Scanner won't read the barcode
you read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Dec 17, 2008 | PSC Quickscan 6500 Handheld
TK-1000
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Aug 27, 2008 | Computers & Internet
Jan 22, 2008 | Symbol LS 4278 Barcode Scanner
Problem with scanner
I have it connected to keyboard port as they instructed.
Sep 02, 2007 | HHP 3800 (015305) Handheld
HHP IT3800 Handheld Logo
2,327 people viewed this question
Top HHP Computers & Internet Experts
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
