Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
After router reset, no connectivity
I was having problems with my wireless. I reset the router (probably a bad idea) and then i was left with no connectivity at all. All the lights are on and green, even the DSL light, but no internet light. I plug directly into the router with a working ethernet cable, and still no internet. 2 Pc's and 1 laptop in my household all have the same problem now. Do i have to reconfigure the router or something? Thank-you.
  • roddery Oct 05, 2008
    It was recommended that I had to reset my 6100. Afterwards lost internet connection. Do I need to uninstall and then reinstall my verizon internet service. I have to software if necesaary. Thanks , WeJacks
    Sergeant:
    Champion:
  • 236 Answers
Yes, you need to setup your internet again.
Use the CD provided.
If you dont have the cd,
go to your modem's home page (usually type "192.168.1.1" in Internet explorer) and look around until you see user name and password. enter all of your info there. if you dont have the user name, password, etc., call your internet service provider. they will give it to you.
hope this helps
Posted on Aug 06, 2008
I have an apple router. Periodically, I cannot connect to Internet. I must unplug router and modem and replug. Things can be fine for days, then it happens again. My cable provider has checked all lines. I...
It's a common problem with wireless routers, especially with certain ISP's, there's several theories about why this happens including cheap parts and software on the routers but it can be much worse if it's over a cable connection. Possibly because the MTU is higher on cable networks than wireless ones. This issue doesn't seem to affect wired connections to the routers as much. ie you may still get a working wired connection even if the wireless isn't working.
Certain makes are known to behave this way, with certain ISP's. eg in england there's a cable company called virgin media, belkin routers really don't seem to like them, but netgear seem to work much better, which is probably why virgin recommend netgear and will only supply netgear routers themselves.
Try changing the channel id if it's wireless, as there may be a lot of interference around you and this may or may not have a bearing on this issue. If that doesn't help then ask your isp what make they recommend as they should have an idea of what will work best, at least the tech support dept should.
In my opinion the best makes of routers are netgear and linksys. I also like belkin although they aren't as good as they used to be, and as mentioned can suffer from this problem quite badly in some cases. As you are with a cable
You will never completely eradicate this problem, all wireless routers will need resetting now and again, but it should be weeks or preferably months between each time. Cisco routers may be more reliable but they're business routers and are very expensive, and probably a bit more complicated to setup.
ps. I used to work for virgin media as tech support.
Jan 18, 2011 | Apple Computers & Internet
Where can I find the password/key for my netgear wireless router
Do you mean the key to log onto your wireless network? Plug a computer directly into the wireless router via the ethernet cable and go to 192.168.0.1. or 192.168.1.1in Internet Explorer. I believe one of those default address for netgear routers. Login to the router, the default login is login:admin password:password then select 'wireless settings' on the left and you should see the key.
If any of the default info has been changed and you cannot login, you will need to reset by pressing the reset button for 30 seconds. But you will have to reconfigure the wireless network and reconnect all computers that were previously connected.
Nov 06, 2010 | Computers & Internet
Hi there, I can't reset the password to my
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 24, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Cannot connect wirelessly thru the router
try first resetting your router. then try relocating the router, have it away from interferences such microwave,refrigerators, or any gadgets that emits electronic noise.
if still the problems persists, try checking on the router's manual, or the website of the router manufacturer.routers have different specific step and procedure on how to setup wireless connections
Jul 02, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
Dec 16, 2009 | Belkin (F5D6230-3) Wireless Router
Netgear router - wireless transmission not working
Try this link, you must turn on wireless to start it.
Have a great day.
Mar 22, 2009 | NetGear WGR614 Wireless Router
Cannot get the wireless going
uninstall and reset everything. you probably had the laptop wireless button in open status when you did initial install, follow the manuf guide guide during setup.
Jun 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless model # WRT54GS
It sounds like the router went bad and your need to get a new one
Mar 05, 2008 | Linksys Wireless-G WRT54GS Router...
I don't have a cd installation ...have no idea how to hook this up..please help
You probably dont need to get any cd, but here is a basic setup. 1. First reset router to factory specs..there is probably some sort of reset hole on the router. With router disconnected Stick paper clip inside and hold while you turn back on router about 10 seconds. 2. Next with computer and Modem turned off plug the Ethernet cable from the modem to the WAN port on the router. 3. Next plug an ethernet cable from the router to the PC. 4. Turn on Modem, then PC it should get you on the internet. 5. Usually the Wireless portion is defaulted to ON, so knowing you have a wired connection, you can now try with your wireless device. 6. Windows will find this signal and it will give you an option to connect to it. When you get an IP address, you will be on. To get into more advanced setup, you will need to get into the router. Try It you should be alright
Feb 27, 2007 | Compaq iPAQ Connection Point CP-2W...
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
133 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
