Question about Ovens
I have a maytag stove model CHE9800BCB. In times past IO have replaced both the clock unit and the relay board.(At separate times) A code showed both times to indicate the problem. This time the clock is blank and no oven control buttons work. Surface elements OK.Have power to L1 of the relay board. How do I check which control is defective?
docjohn174
  • 943 Answers
SOURCE: Stove top element overheats
HI thanks for your question. the problem is with the burner switch. replace the switch. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 11, 2008
abhishek33
  • 1239 Answers
SOURCE: amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Posted on Nov 16, 2008
SOURCE: Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Posted on Sep 14, 2009
dmftrucker
  • 1922 Answers
SOURCE: stove is not getting hot or elements
sounds like you've lost one phase of your 240 volt power
Posted on Oct 05, 2009
My maytag flashes the code F1. What does that mean?
I just went through the same thing. According to what I have researched, it means a problem with the touchpad. Found out the clock/touchpad can run up to $200 to replace minus labor. I had nothing to lose so I took the back panel off the stove, took out the unit which is held with 4 screws, and used alcohol on a qtip to clean the circuit board. Mind you the stove is 15 years old and wasn't about to pay 200 dollars for a part. Put it all back together and the error code went away and the oven is now working again. It is getting me through Thanksgiving but I am buying a new stove because I don't know how long this repair will last. You have to consider the age of your range and what you are willing to pay.
Oct 18, 2014 | Maytag Ovens
Maytag stove model JJW9530AAW not working
https://removeandreplace.com/2017/03/21/maytag-oven-error-codes-stove-range-fault-codes-causes-and-solutions/
Nov 20, 2017 | Stoves Ovens
In edit mode my oven seems to warm up past the preset temps and trip the overheat relay, also in cool down mode when i open the door it shows the IR steadily going higher to 1000F and seems to stay in cool...
Bad SSR relay, te relay is shorted it keeps feeding the power to the it element . Or else bad IO board. You should know how to diagnose it though. Otherwise don't touch it
Feb 18, 2012 | TurboChef TORNADO Electric Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven goes off and f2 or f5comes up , what does this mean?
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
Error codes for American stoves with service manuals and more HERE
Thanks for using FixYa
Jan 08, 2011 | Maytag Ovens
On the window where it shows the clock time, it showed error E0 F2. The stove top works but the oven stop from working. All the digital numbers and all keypad entry was not functioning. For the whole time...
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). Follow the link for diagrams and illustrations of your specific model.
Oct 14, 2010 | Ovens
I'm getting an error message F2 and the broiler will not turn off. It came on bt itself while the bake was on!
F2 on most jenn-air ranges/wall ovens indicates a fault in the oven sensor or relay board. I'd first check the sensor, (part # 12001655) it should ohm out at approx. 1100ohm @ room temp. If it is OK, it's probably a faulty "broil" relay and suggest replacing the power relay board.
The board (usually seperate from the clock and just behind it), on earlier model jenn-air/magic chef/norge/maytag etc. where known to burn up. part # VO4100260. double check those numbers with your model number at your local parts depot or service provider, those are just the most common for maytag built units.
hope that helps,
good luck
Oct 03, 2009 | Ovens
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F2,F5,F7 message
MAYTAG
Code
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
