Question about Dishwashers
Water appears on the floor and error E1 lights up on gorenje dishwasher
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
  • 210 Answers
SOURCE: LG LD-A2T2 Dishwasher returns Error code E1
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
Posted on Jun 19, 2008
Richie_asg1
  • 1036 Answers
SOURCE: E1 fault code Dishwasher runs for
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Posted on Aug 05, 2009
SOURCE: gorenje dishwasher comes up with an alarm and an
de dishwasher does not fill wather
Posted on May 27, 2010
SOURCE: Hi Kenwood dishwasher kdw60x10 -
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
Posted on Jun 03, 2011
E1 error code on omega dishwasher
E1 error on LG Dishwasher - YouTube
? 2:40
www.youtube.com/watch?v=2qcwAyHI9ik
Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
Aug 28, 2015 | Dishwashers
Why is my lg dishwasher leaking and not draining completly
Chances are that the water pump seal has deteriorated to the point where the water has leaked into the pump (and the floor) and caused problems with corrosion.
You might have had an E1 error code on the panel as well, if not, check out all the hoses for kinks etc then check the water pump condition for leakage. If it leaks, you will have to replace it as it is a sealed unit.
Jul 17, 2014 | LG LDF6810ST Stainless Steel Built-in...
HOW TO CLEAR CODE E1 ON LG DISHWASHER ?
The 1E error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Jun 13, 2014 | LG LDF7561ST FulIntegrated Dishwasher with...
E1 error on Baumatic BAD6003
If you are getting E1 error then the dishwasher is suggesting that water is getting in but not enough. But if you are getting no water into the dishwasher then the water inlet valve inside it is faulty. Have you checked if there is water inside the dishwasher when you get E1 error. Another thing to find out is the water pressure specification of dishwasher and whether it is consistent with the mains pressure in the house. Usually there should be a plate on dishwasher door which would give water pressure required.
Apr 20, 2014 | Baumatic Dishwashers
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
LG dishwasher model LDS4821- 16 months old- getting E1 error. Water leaking on floor. This happened before 3 months ago but then had no other problems with it until now. No other problems with this machine...
Hi ferrojennife,
The E1 you are seeing means Water Level in Drum lowering, this means there is a leak on one of the pipes. More likely it is the Circulation Pump, which is responsible for pushing the water to the Spray arms.
It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote for it
Jun 09, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
I have error code e1
Hi. Sorry this is so late, but I just happened across this post, so I thought I'd see if you have solved your problem yet. The EI code most often is caused by water leaving the tub during the wash cycle. The most common cause of this is that the dishwasher drain hose does not have a high loop in it. Often, the installer ran the hose right down through the floor. It needs to loop up high before going to the drain to prevent water loss, and a resulting IE code.
Oct 25, 2008 | LG LDF6810 Built-in Dishwasher
Sgt 48
Jun 18, 2008 | LG Dishwashers
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
145 people viewed this question
Top Dishwashers Experts
