Question about Emerson Televison & Video
I have Emerson TV/ VCR / Dvd. The tape rewinds,but just before time to stop/eject, the power turns off. Is it safe for me to squirt WD40 into the slot when there's no tape inside? Or should I just buy a new unit? Betty
  • Emerson Master
  • 5,126 Answers
Do not put wd40 into the unit as it could attack plastic parts making it worse. You can squirt Servisol Video 40 without harm to the device. However i would have a look inside by taking the top cover off and see if you can see any damage or objects stuck etc. If you can find the VCR's mode switch that might need a clean with Servisol.
Posted on Apr 08, 2011
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Tv turns on but will not play tape that is in the machine. after
some times you can hit the power and eject button about the same time and it will eject the tape try this a couple of times to see what happens if that does not work then you can take the back off after you unplug from outlet for ac there is a belt that is black that should look like a long ruberband turn the pullys one way or the other to eject the tape manualy.
Feb 11, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
co6bg@yahoo.com
Feb 02, 2009 | Emerson EWD2202 DVD Player/VCR
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Emerson EWR20V4
this is more of a belt problem, look for a worned belt.
May 16, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Tape stuck in VCR, won't eject.
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod. good luck.
Jan 24, 2007 | Emerson EWV601 S-VHS VCR
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
51 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
