Question about Plantronics Savi Office Wireless Cordless Headset Wo100
Savi Office WO100 won't charge. The green light on the base is blinking but my computer says there is 0% percent charge.
  • KM Aug 16, 2012
    I have had this happen a few times now. The first time it was sent back as defective and replaced. The Second time i left it off the charger all weekend and put back on on Monday and that seemed to do the trick.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
There are two possible solutions to this issue:
1. The headset needs to be reset.
2. The headset is defective and should be replaced.
To reset the headset, use a straightened paperclip to push the reset button on the inside of the headset, below the earhook. See the pic:
You may need to hold the reset button for a few seconds. Then replace the headset into the cradle. You should see normal behavior again.
If this doesn't work. you will need to replace the headset.
Posted on Aug 14, 2012
  • BillStein Dec 11, 2013
    Leaving the headset out of the cradle "over the weekend" effectively drained the battery, causing a hard reset as there was no further power to the headset. Resetting it with a paper clip or draining the battery both accomplish the same reset.
I want to buy a wireless headset please suggest me a good one ?
The Savi W745 is a headset based upon Digital Signal Processing Technology launched by Plantronics. Plantronics Savi W745 has an excellent NC (Noise Cancelling) microphone having up to 3 different styles. This headset has a talk-time period of up to 7 hours and can optimized for Avaya, Skype etc and a 350' Bluetooth range connectivity.
May 23, 2017 | The Computers & Internet
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
Turns the power button on and the power light keeps blinking in and out and the computer won;t come on
I would look into testing the laptop by taking out the battery and plugging in solely the charger, and try turning it on. If it doesn't work, it sounds like it can probably be an issue with the Motherboard or the RAM.
Is the blinking light an amber or green color? If amber, then it might be a RAM issue. If green, the power would be on, but the monitor might not be active/working.
Apr 03, 2011 | Acer Aspire AS7741-7870 Notebook PC and...
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Plantronics Savi Office Wireless Cordless Headset Wo100 Logo
1,627 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
