Question about Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum
Hoover Duros; Off on switch will not stay on.How do I fix it or where is there a service shop in Winnipeg Manitba?
My Hoover Duros (blue color, S3000 something model with the power brush) worked fine for 3 years, than it died. The other day I couldn't turn it on... What can it be? A fuse? Where's is the fist in...
manual > http://hoover.com/file/682/
To reset the breaker:
(1) Push the ON/OFF switch
http://hoover.com/file/682/completely
down. You will feel some
resistance when the switch moves
downward. The switch will also move
slightly upward on its own.
(2) Wait one minute.
(3) Repeat step 1.
(4) Turn the cleaner ON and continue
cleaning.
If the brushes continue to stall and
the breaker trips again, clean the
brushes to remove debris. (Figs. 4-1
through 4-4)
To reset the breaker:(1) Push the ON/OFF switch
completely
down. You will feel someresistance when the switch movesdownward. The switch will also moveslightly upward on its own.(2) Wait one minute.(3) Repeat step 1.(4) Turn the cleaner ON and continuecleaning.If the brushes continue to stall andthe breaker trips again, clean thebrushes to remove debris. (Figs. 4-1through 4-4)
Jul 28, 2013 | Vacuums
Hoover duros 3590
dont no wot you wont but here is the manual > http://hoover.com/file/396/
Nov 25, 2012 | Maytag Hoover Duros S3590 Vacuum...
Hoover elite power wont stay on
go to http://hoover.com/ and get the section support download the inst.manual, section troubleshooting, videos for guide for troubleshooting and fix it.
God bless you
Sep 16, 2012 | Hoover Elite Rewind Bagless Upright...
Hoover duros no suction
you must see any clogged from Hose, or nozzles, and clean, or repair.
Will be a good idea tha yur use user manual, or download from the Hoover.com and proceed according.
God bless you
May 27, 2012 | Maytag Hoover Duros S3590 Vacuum...
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
I don't know how to change the bag for the machine, bag # SR 401010. Vaccum is Maytag Legacy series. Is there a diagram or picture to show how to replace the bag. Thanks
http://www.hoover.com/CustomerService/Manuals/Default.aspx Enter your model number on Hoover's website to view or print a manual. I suspect that you may have accidentally discarded the bag frame ( part # 93001544 ), which holds the bag in position.
May 21, 2011 | Maytag Hoover Duros S3590 Vacuum...
Vacuum won't stay on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618732&thid=562398
posted by trobinson66 on May 01, 2008
I think the switch is broken--it will come on, but the switch does not stay engaged. I'd like to try to fix myself, if possible. Any thoughts?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover Telios Canister Vacuum Powerteam
When you uninstalled the switch did you mark the wires to duplicate the procedure in re- installing the part, it is possible that you have a bad switch, please check your owner’s manual for the trouble shooting guide to see what you might have done wrong. If the switch is wired correctly it should work, but one wire could be off and not connected correctly then the switch will not work. Feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Hoover Telios Canister Vac Vacuum
Power switch will not work
Hoover U6437-900 U6439-900 Windtunnel Upright
seems there is a short in the power switch, is that possible, I have it disassembled and seems there is power going into the on/off button, but will only sporadically turn on
This could be a defective switch or it could be a loose connection or wire – chances are that it is a defective switch and needs replacement – this could be a slider switch of which does wear out and that is why it will comes on sporadically – if there is a local vacuum cleaner shop in your area they can test the switch and possibly sell you a new one
Telephone
8 a.m. - 7 p.m. EST
Apr 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Embedded Dirt Finder green light won't come back on - stays red
The dirt sensor is a motion detector. After it gets dirty it will either stay red or stay green. You can have the vacuum serviced at your local vac shop and possibly get this fixed. Sometimes they are as good as new and sometimes they are not repairable. It will not effect anything else though.
Jun 09, 2017 | Hoover U6634-900 WindTunnel Bagless...
Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum Logo
178 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
