Question about Vacuums
Marshmellow exploded in my ge jvm1190sy micr/convection oven and went thru the holes on the roof of the oven..i can not clean it any ideas? there is a layer of marshmellow and when i put convect oven on a fire started
    Problem Solver:
  • 6 Answers
You will need to steam the debris out. Place a microwave proof dish half full of water and two tablespoons of white vinegar into the microwave. Heat on high for two minutes. Let this sit for two or three minutes then heat again for thirty seconds. Take a warm damp towel and then try to remove the marshmellow. Don't use a paper towel or sponge. Keep boiling the water/vinegar and rubbing with the damp towel until everything is removed. Its going to take a while but you will eventually get it all.
Posted on Apr 09, 2011
Little green machine will not spray cleaner
Have you checked the tiny hole that the spray comes out of. I have one and sometimes it becomes clogged. I take a small needle and run it thru it.
Oct 09, 2014 | Bissell THE BISSELL LITTLE GREEN MACHINE...
My hose is on the suction side of the Ridgid Dry Vac but its still blowing out of the other hole. How do I fix this?
it is supposed to blow out the other hole. in order for a vacuum cleaner to suck things up, it also takes in air. That air passes thru a filter leaving the debris inside the canister, and then exits thru the other hole.
Sep 29, 2013 | Vacuums
I cannot find the link to register my new convection toaster oven.
I would like to see if I could help you but, maybe I'm missing it, but I don't know what kind of toaster oven you have.
<a href="toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 15, 2011 | Vacuums
I need a manual for Betty Crocker convection oven model # 1682
It is best to call the Customer Service number for more information about the convection oven. From there, they will ask for your name and address, then send you a copy of the manual.
Please call
1-800-446-1898 between (7:30 a.m. - 5:30 p.m. CT, weekdays)
Nov 29, 2010 | Vacuums
Manual for GE microwave spacemaker oven GE proffile
here is a website that can help you obtain a manual
Of course they will need the model number of yours
http://www.google.com/search?client=ubuntu&channel=fs&q=manual+for+GE+microwave+spacemaker+oven+GE+proffile&ie=utf-8&oe=utf-8
Sep 03, 2010 | Vacuums
No sign of water movement from cleaning heads
My Bissell ProHeat is not dispensing water thru the floor cleaning position. I get water flow thru the tool application. Any ideas???
Apr 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My model S3202C Shark Steam Mop does not heat up or produce a lot of steam and is about 6 months old Please advise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Jan 09, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heating up but not producing steam. Tank may be furred up as limescale deposits in water when tank emptied.
OK. This is an actual guaranteed solution to the Shark "No Steam" problem. The problem is well documented as hard water clogs the steam mops head. And using distilled water should prevent problem (not confirmed). But now that you have the problem, how do you unclog?
First off, Ive had two now. And my solution probably invalidates 1 year warranty, but I'm not interested in going through all the rigamarole of taking my mop back to the store. Maybe yours has expired or you want solution now like me.
This requires a drill. If you've tried the white vinegar route like me and it hasn't worked, and the toothpick, now it's time to get serious.
Remove the four screws. Then slide connection back and remove final two screws. Try blowing thru the small round hole at the end of the connector. If you can't blow through it, the smallest choke point near the hole is your problem.
Using the smallest drill bit in the standard drill set (not sure the size but it fits easily in the hole with room to spare) drill gently into the hole until it breaks thru the first resistance. Now blow through the hole. It should blow through easily now. Run some white vinegar thru to loosen up and remove other hard water deposits if you like.
Replace nozel. Replace two screws, Replace 4 screws. Done.
Use only bottled distilled water from now on would probably be a good idea.
In my opinion the problem is a design flaw built in by the Shark people. Appropriate name. Its called planned obsolescence. :( It breaks, you buy a new mop head (or entire mop if you can't find their part's website.)
Sep 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
