Question about Huffy Cycling
Can I replace the back wheel bearings on my huffy Stalker bike myself easily??
    Brigadier General:
  • 8,546 Answers
That's up to you and your abilities and available tools...
http://www.parktool.com/blog/repair-help/categories/hub-service
Posted on Apr 07, 2011
Have an older Huffy female 12-spd road bike that is missing the rear wheel assembly. Looking to find a replacement as well as instruction manual...wheel assy. more important. Thanks.
Unless you have a deep sentimental connection with the bike, it may not be with it:
Rear wheel - $35-$45
Rim strip/tape - $1
Tube - $8-14
Tire - $10-20
Gear cluster - $25-40
New Huffy is about $150-250
You might be able to find a used bike or wheel at a garage sale that would work.
Sep 19, 2015 | Huffy Cycling
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area
or you can take the hub apart and fill with a very light grease
Jul 23, 2015 | Huffy Cycling
What is the replacement pedal bearing in a huffy mountain 24" bike?
at the Huffy quality level of pedals, you most likely won't be able to service the part, you can find a set of replacement pedals at your local bike shop starting at about $10 for the pair.
Apr 28, 2014 | Huffy Cycling
I took apart the back wheel of the bike and now dont know how to put the bearing and axle back together
I take it your bicycle has a coaster brake. Can you tell me what brand the hub is? It is probably stamped on the brake arm that attaches to the frame.
Aug 10, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
Where can I find a replacement bearing?
I recently replaced a wheel bearing in my daughter's bike by just keeping my eye open for a junk bike. There are not all that many different sizes of bicycle wheel bearings to be had. The junk bike doesn't have to be a very similar bike or even be a child's bike. I got lucky on the first one I found. And it was free. Or you could take the bike to any bike store and they would probably have a bearing on-hand, but they will probably want $15 for it. good luck
Dec 15, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
Ineed to replace rear wheel bearings
Why do you say that? Did a professional bike technician tell you? You may be better off buying a new wheel unless you have the tools and the know how to rebuild your rear hub.
Sep 27, 2010 | Huffy 26in Ladies Sante Fe Cruiser Bike -...
Need a bearing size or part number to replace a pedal bearing in a huffy stone mountain multi speed 26" bike
Pedal bearing or bottom bracket bearing? Your best bet would be to take it to a local Bike Shop and have them assess it.
Aug 04, 2010 | Huffy Cycling
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Girls Huffy 16" bike - back wheel does not spin freely. It tightens up after a few spins.
Try the bearings. Try a different wheel and rim. If its not the wheel then the crank bearings( ones the pedals are on) could be bad or the chain could be not set right.
Dec 24, 2008 | Huffy 16 In. Girls Dora The Explorer...
Cycling Logo
127 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
