Question about Hobart 41 in. AM14-255 Free-standing Dishwasher
I have a Hobart AM14. The wash cycle is fine but it will not go out of rinse cycle. Can I change that by reprogramming the control board?
  • 37 Answers
Does rinse run even with power off could be a stuck valve.
Posted on Apr 22, 2011
Time program for Dishwasher Hobart m14
Depends on the version of the control board. If its the original, with a large heat sink near the center you can only adjust the rinse lenght by adding a jumper. Look on the right side near the middle to top. you will see a place to add the jumper in a set of pins, near where the jumper is for low or high temp options.
If it's the new style, you can short the two pins and go into factory service mode. Use the buttons on the board to advance through the options while monitoring the display. the Up arrow will incriment through each option. Powering off will save the changes.
Jan 29, 2014 | Hobart AM14-253 Free-standing Dishwasher
AM14 Display will stay in Rinse Cycle
see this probably causes:
Water-heating cycle
the heating will be importante, test the hot water, and heating elements
Timer
test the timer for contact, and probably defective.see the diagram attached.
May 07, 2012 | Hobart AM14-253 Free-standing Dishwasher
Commmercial dishwasher has proper pressure when
same pump does both, are you certain there is nothing in front of the pump? I would pull the safety hood off and look inside
Jun 29, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart dishwasher Am14, rinse cycle is too short. Can it be adjusted?
no rinse time can't be adjust on the am-14 modelit is built in main board non variable
Dec 01, 2009 | Hobart SR24C-4 Dishwasher
Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Oct 01, 2009 | Hobart AM14-253 Free-standing Dishwasher
Hobart am 14 constant power on rps 1+2, rinse conection has power even when machine is in wash cycle
DPS1 and 2 are fed from L1 and L2 directly.
RPS1 and 2 get their signal from a relay, triggered during fill or rinse. Check inside the control box for the machine schematic and component location. Check that the relay only powers during fill and rinse. Check for welded relay contacts.
Note. Soap and rinse dispenses are often spliced into AM14's in unusual ways, and with unprotected pump circuits. (no fuses) These can be too much current draw for the contact rating of the relay.
Jul 02, 2009 | Hobart AM14-253 Free-standing Dishwasher
AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Feb 26, 2009 | Hobart AM14-253 Free-standing Dishwasher
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart 41 in. AM14-255 Free-standing Dishwasher Logo
258 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
