Question about Saitek Pro Flight Throttle Quandrant Joystick
Worn out to fast at the top end of the throttle,can it be repaired,have already changed 2 over,replacement part or repair , many thanks js SAITEK THROTTLE QUANTRANT
  • 50 Answers
Unfortunately Saitek does not have a repair service therefore no spare parts are available at all.
If your Throttle Quadrant was bought less then 2 years ago you should be able to get a replacement for it from your retailer or from Saitek.
Hope it helps...
Posted on May 01, 2011
My saitek x52 joystick wont work. Flashing lights every half second. Throttle works fine.
My X52 began doing this after hundreds of hours of use. Joystick lights flashing twice per second. Throttle operative but joystick (and buttons) not.
The problem was 2 wires inside the joystick base that had eventually been sawed in half by the sharp edge of the metal tube that carries the wires up into the stick. I have no doubt that this same issue could cause intermittent operation if just the insulation is worn off of more than one wire.
The fix: Remove the 4 screws from the base and lift the joystick assy out of the base. Inspect the wires where they emerge from the metal tube. You will find wires broken, or, insulation rubbed off. If you have broken wires, strip the ends and solder them together...you should have about 1/4 inch of "slop" up in the top end so you can pull the top wires down enough to strip and solder. If you re-insulate the solder splices with heat shrink or spaghetti tubing I would keep the amount used minimal...these wires need to remain somewhat flexible when the stick is being used.
Finally, I fixed the engineering defect that caused this in the first place by immobilizing the wire bundle with hot glue at the tube opening to prevent future contact with the sharp tube end. If your only problem was skinned insulation, this hot glue application may be all you need to do to keep the exposed conductors from contacting each other or the tube.
Speaking of "slop", you will also be contending with a bunch of silicone grease that lubricates the wire and mechanism.
Jun 12, 2011 | Saitek X52 Flight Control System
I need the cable from the stick to the throttle on a Saitek X52. Looks like a straight PS/2 cable, is it?
Yes the cable is a PS/2 cable at both ends.
It's a standard one you can get it anywhere, any electronic store, ebay...
Hope it helps...
Jul 27, 2010 | Saitek X52 Flight Control System
Saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
One week after front end collision repair, throttle body goes bad
Was the damage to the throttle body impact or was it worn out.
Aug 27, 2009 | 2004 Ford Explorer
Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
Throttle stick not working properly.
take it back to seller heap of cr*p
Jun 20, 2009 | Ubi Soft IL-2 1946 PC
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
AC Adapter for Konka TV
All I'm looking for is a Jewel AC Adapter Model JS-12030-2E.
thanks
Gary
Jul 22, 2008 | Televison & Video
Saitek Pro Flight Throttle Quandrant Joystick Logo
328 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
juanmireles1
Michael Vincent Cruz
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
