Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
My refrigerator is not getting cold what is the problem? I have cleaned the coils and unplugged the unit and left it overnight and still no chill...
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Posted on Apr 07, 2011
My Indesit fridge does not get cold, both the Refrigerator and Freezer.
ok.. none of what you have done involved taking the back off.. if you can get to the compressor itself, you will find it has a dinky 'computer' style fan.. but invariably, some fool of a designer, runs wires very close, and uses low quality cable ties.. which break, causing the wires to spring up and jam the fan.. (especially if it has been moved recently) significantly reducing your compressors ability to chill your appliance.
get some decent cable ties, check and secure rogue wires, and things should sort themselves back to the right temperatures within a few hours.
Apr 24, 2017 | Indesit Refrigerators
Maytag MTB1972HRW refrigerator (freezer on top) freezer is not cold, refrigerator seems to chill just fine. (noauto icemaker)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
Have a old Servis Upright Fridge Freezer. Haven't defrosted in a while and then found all thawed. Left switch off overnight and turned on this morning. Fridge light working but no noise and neither...
Sounds like the compressor up and died...
heatman101
Aug 26, 2011 | Refrigerators
My magic chef model MCBR1010W refrigerator went room temperature but the light coes on. When I unplugged it overnight and plugged it in the next morning it started to work. I want to try cleaning the coils...
heatman101
Jun 09, 2011 | Magic Chef Refrigerators
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
ONLY BLOWING SEMI COLD AIR> NOT REAL COLD LIKE IT SHOULD BE. cleaned front condencer still not ice cold. worked fine two days ago
return air ducts are iced up , unplug unit overnight or use a blow dryer in the freezer area. Ducts are behind rear panel left and right side
Nov 27, 2009 | Kenmore 53642 / 53644 Side by Side...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
The fridge is not getting cold, frezzer is working fine
unplug unit and let defrost overnight, use a blow dryer to speed things up if you like , return air ducts are iced up by the evaporator coil,
Nov 06, 2009 | Maytag MZD2766GES Side by Side...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
98 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
