Question about Cobra 29 LTD CB Radio
I done a swing mod to my cobra 29 nw st wx and got the rf gain blue wire and the mic gain wires backwards at the switch tryed to transmit nothing but a squeal figured out what i done fixed the wires now it dosent transmit light comes on but meter swing backwards
  • 3,018 Answers
Which swing mod did you do? The one where you pull the jumper and put a capacitor in it's place? If so did you bias it with a resistor on the soldier side of the board? If so what Ohm resistor did you use? What size capacitor? Did you install the capacitor with the black stripe towards the back of the radio? How did you make your way down to the mic wiring from installing a "swing kit?" The wires you crossed would make a squeal but should not effect anything once fixed. If you will answer the questions posed I can further assist you.
Regards, Tony
Posted on Apr 07, 2011
Hi,i have a cobra 29 ltd radio .the problem is this i can hear prople great but when i key up people barely hear me even thou i have my mic gain up and dinamic up as well. also when i key up my cb makes i...
You said mic gain and dynamic as well. After market power mic? Battery in power mic good? and is it wired for that radio? Running a "mag mount" antenna? Make sure your radio "power" itself has a good ground. In some cases the chassis of the radio may have to be grounded as well. Your getting some type of feedback, whether its audio or RF related just might have to play with it a bit.
Nov 11, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
Need to wire a high gear m75 for acobra sound tracker
It should already be wired for that radio. Its a cobra mic, on a cobra radio, its all wired for cobra. Witch is a very common mic wiring.
Nov 09, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
We have a Cobra 148 nw st Sound Tracker When
It could be..
Final blown : worst case
bad mic : try another one
CB/PA switch on PA instead of CB
CB/WX swithc on WX instead of CB :you cannot transmit on weather.
Broken wire on mic jack.
Try the mic and switches first, and if that doesn't help you may need to take to tech. You can find one at a cb shop usually at truck stops.
Oct 27, 2009 | Radio Communications
Have cobra 29wxnwst radio. Truck sat for 3 months
Turn up the RF gain all the way and leave it.
RF gain is basically how open your receive is. There is really no reason ever to have it down unless you are trying to hear only close stations to you.
If you RF gain is up, your mic pins my be oxidized, or mic bad.
Try a different mic, and or clean the contacts in the connectors.
Sep 18, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
Aug 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Trying to hook up a astatic echo board
Looking at the plug from inside the radio, with the nub facing downward, from right to left you have pin1 pin2 pin3 and pin4.
1-Shield
2-Audio
3-Transmit
4-Receive
Colors are
1- Red
2-White
3-Blue
4-Black
Mar 24, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 wx st
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Feb 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
I can hear others but when i talk noone hears me
Try switching a different mic, sometimes the transmitting wire comes loose inside the connector. If you are handy enough, you can even unscrew those two tiny screws on the end of the mic cord and see if a wire is loose and if so, solder it back into place.
Oct 04, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Transmits but doesnt receive
If the meter shows that it's receiving something, the microphone may be the problem. Another possibility is the speaker & plugging an external speaker in would confirm this. Aslo make sure the squelch control is turned all the way to the left (counter-clockwise) & the RF gain is turned to the right (clockwise).
Jul 18, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Not real sure
Make sure that the mike gain & RF gain controls are turned clockwise & the squelch is counter-clockwise.
Jun 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
32 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
