Question about Dishwashers
Have a crs66a hobart dishwasher that when you shut the machine off the water still continues to fill the machine
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
SOURCE: lx 30 h hobart dishwasher
I hd the same problem. water was boiling during even when the machine was not washing. I replaced the temperature probe located inside the sump, and the problem was solved.
Posted on Aug 22, 2008
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
  • 3 Answers
SOURCE: not filling water not rinsing
call 828-484-9562
Posted on Mar 06, 2009
SOURCE: Hobart lx40 Dishwasher stopped working
the reason according me this to be happend,is a short circuit somewhere in the machine,it could be the heater,solenoid valve or to be caused by any leakage,you may check the fuse and replaced if necesary,and if that continue you need a technician.
Posted on Apr 19, 2009
Model lxic keeps filling with water
If you have a problem with your washer or dishwasher continuing to fill with water after the valve has closed, then you this tip will help you understand why that is happening.
Here is a tip that will help you...
Washer or Dishwasher Fills with Water when off
heatman101
Apr 12, 2011 | Hobart Dishwashers
Have a hobart LX18 it will not fill can you help
hello,
A Dishwasher is a high quality product that focuses on energy efficiency. In addition to saving money on electrical use over other machines, they use less water than the average dishwasher. When your Dishwasher is not filling with water properly, before you call for a service appointment, check the components yourself.
    instruction
  1. Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
    If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
    There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
thanks.
Oct 23, 2010 | Hobart Dishwashers
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
Nov 21, 2009 | Hobart Dishwashers
Where can I find a mnaual that can tell me how to de-lime a Hobart CRS66A Dishwasher?
I doubt that the user manual covers de-liming the Hobart Dishwasher.   If I owned this (fine, expensive) dishwasher, this is what I would do.
1.) Discard any generic, ultra-cheap detergent.  Stop using gels or tablets and only use powders.  Buy a box of brand name powder (like Electrosol or Cascade)  You will be amazed how much difference that will make because the newest generics have mineral bulk added that build up faster then hard water does on both the stainless steel enclosure plus the silverware and even plates.  White patches.  I LOVE generic products and saving money, but low end dishwasher powder is one place I no longer choose a generic product.
2.) Add two cups of white vinegar to the empty dishwasher and leave it there until the morning.  Run a quick cycle with no detergent added.  The vinegar will be pumped out immediately after you begin this quick cycle.
3.) As soon as the dishwasher fills with water during that quick cycle and begins a wash cycle, add two cups of white vinegar and close the door and allow to run the full wash cycle.
4.) When the dishwasher finishes the drain cycle and begins to fill again, open the dishwasher and check the enclosure for remaining "lime" deposits.  If they remain, keep adding 2 cups white vinegar each time the dishwasher refills and begins to wash/rinse again.
You should be delighted with the results. Long term, you should consider adding a whole house water softener and then reduce the amount of dishwasher (and laundry) detergent by one half.  Amazing increase in quality of life by adding a water softener.  You will be delighted.
Please post back with you results, OK?  Good Luck!
Apr 17, 2009 | Dishwashers
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Look behind the dishwasher and you will see a cover on the right side,remove it.You may see a transformer with a fuse,check the fuse with a meter if you know how.Open the door look up to the right and left,you should see 2 phillip head screws,remove.Pull the top drawer with the display towards you.If you get this far let me know.
Apr 07, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Am14 will not stop filling on initial fill
Check the underneath the drain stem (lift up food catching screens inside the machine - drain stem will look like a long hard plastic tube) you may nee a flashligh when you tak out the tube to see the actual drain hole/ swirl your finger around the hole to make sure there are no toothpicks etc... also check on that plastic drain stem that there is a black rubber o-ring at the end of it - and is still tight.
also inside the machine there will be some plastic bubbles- (these are your float switches, which rise and shut off the fill when the water gets high enough. make sure they move either up or down (not both)
Write back if it still continues to fill
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Owen Barnes
