Washing machine works good, but the top canter part does does not move back and fourth. just the bottom part does.
  • Washing Mach... Master
  • 2,699 Answers
Copy and paste this and watch the video,it should help you out.....http://www.youtube.com/watch?v=V5wIN1J70-Y.............you need a new set of dogs or a kit with all the parts you need,call your parts store,give them the model number and they will give you what you need.
Posted on Apr 07, 2011
How do I fix...?a timing of colt 2.500 diesel
, proper way is to use diesel timing light and set pump canter to correct position(assuming good pump ) , close enough way , accelerate to half rpm , turn pump canter (angle) till smoke out tailpipe turns from black to white(or vice versa) then move slightly back , tighten pump down and retest , might be needed to go back and forth a few times to get it just perfect
Jul 29, 2015 | Cars & Trucks
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
Take the top off
To remove top: Remove bottom screw from plastic clip on back side of washer's top. Stand in front of machine and use the palms of your hands to sharply push back on the L and R edges of the washer's top. After top moves back about 2 inches, lift top off.
Feb 19, 2011 | LG WM2050C Front Load Washer
Kenmore Elite Washer Mod 110 27062601 Ser CT 3770465 The load will not stay level. I checked the suspension rods and compared spring strength to a new assembly. They feel the same. The tub is suspended ok...
I would still replace the suspension rods and bushings. Not much else it could be if machine is level and clothes are distributed evenly. I also have seen the cabinet weld separate at bottom, so be sure cabinet is secure.
Nov 04, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator for whirlpool washing machine
The plastic dogs are stripped inside the center of the agitator. To remove agitator pop off the top center cover(slot for screwdriver) There is a 7/16 inch bolt with standard thread, remove it and pull out agitator. Pull the agitator apart, you can stand on the bottom half and pull on the top, you have to reassemble it with the new dogs replaced(there are four in a package) Fairly simple, no special tools needed,
good luck.
May 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stuck between wash and rinse.
first remove agitator by taking top of agitator off and putting your hand down the centre of it and unscrewing the wingnut holding the agitator to the main drive shaft. once the nut is loose pull the agitator out and bail the water out by hand using a pot or jug. once the bowl is empty u can look underneath. to the right hand side front of machine u will see a red or black fan that is attached to the pump. turn the fan clockwise and then anti clockwise and hopefully that will unjam the pump. the fan should turn freely. then put machine back on its feet.refit agitator. turn on unit select spin and it should start draining.if it doesnt reply back and i will help u more. please turn off power to unit b4 u work on it. good luck
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
The copies print with 2 white streaks where print should be
pull the toner/drum unit out of the machine. on the top of the drum unit there is ether a blue or green slide lever. move the slide back and fourth 10-15 times. if you have canned air blow out the area where the slide is. reinstall the drum unit see if this works
Good Luck
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
My whirlpool top loader won't agitate.
Peace Friend,
ngfam1 At your service!
You did nothing to cause this! Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is broken!
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
I
Aug 31, 2008 | Washing Machines
Frigidaire washing machine pump is making noise
Remove two screwn on bottem of front lower panel. Clamp hose clamp on large hose leading to front of pump assymbly, twist back and fourth the hose while pulling back to remove hose ( some water may flow if pump is not working right) Once the hose is removed you can see into the pump turbine and move it circular with a small screwdriver to see if it spins freely. I had this same problem and found a bobbie pin stuck partially into the pump. I removed the pin and everything works like new.
Mar 31, 2008 | Frigidaire GLTF2940ES Front Load Washer
Won't hardly spin
the back and fourth motion is normal. we have a ge and it does the same thing. for the slow spin and burt rubber smell the drive belt is more than likely streched, the fast fix is to replace the belt. HOPE IT WORKS FOR YOU!
Feb 12, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
