Question about Toshiba TEC B SX4T Printer
I am trying to run a transfer label with ribbon and can't get the ribbon to rewind.
    Champion:
  • 254 Answers
Check in your print options if you are not in direct thermal.
You should be in tthermal transfer
Posted on Aug 16, 2011
Ribbon rewind does not operate, labels print but ribbon comes out the front of printer with the label?
Have you selected thermal transfer in the driver?
This is the normal cause for ribbon not rewinding.
Aug 25, 2013 | Toshiba B-SV4D Label Printer
The Ribbon is sticking to the paper, as the paper is fed. The rewind motor shaft is turning also.
check that you are in thermal transfer mode in the driver.
- Check in the diagnostics mode that the ribn Adj Fwd is not -15
Normally should be zero
Sep 26, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
I want to change the printer ribbon on Zebra s600 203 dpi, is there a way it will rewind existing ribbon off?
Thermal printers don't use ribbons or ink. They transfer images/text with heat on to special thermal paper.
Mar 23, 2011 | Zebra Stripe S600 Thermal Label Printer
The ribbon keeps being fed through along with the labels..
Go to the settings in your driver and select thermal transfer instead of direct thermal. This will activate the rewind motor
Jan 06, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
Ribbon fult
You get a ribbon fault when the ribbon is out, or sometimes when your printer isn't rewinding the spent ribbon well.
I find that if I pop open the printer and manually advance the ribbon a few times, it will work corrrectly.
I have been told that this could be an issue with the clutch on the rewind spool as well.
Jun 05, 2010 | Datamax M-4208 Thermal Label Printer
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Jun 03, 2008 | Datamax DMX-I-4212 Label Printer
65 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
