Question about Brother HL-5240 Laser Printer
How do you load toner - Brother HL-5240 Laser Printer
    New Friend:
  • 142 Answers
Open front cover and pull out drum unit. If you allready have the new toner you will see where it is situated on the dum unit. Look for a little blue lever and push it to unlock the toner
pifonski
Posted on Apr 07, 2011
Toner will not loan
Either toner transport pipe cloged or toner pump gone. Only new pump will solve it, but first I would check the rubber pipe that transports the toner. That is most likely
Apr 18, 2014 | Ricoh AFICIO MPC3500 1-SD YLD BLACK TONER...
My printer is saying "
This error means that the paper is not loaded properly, or the toner cartridge is not set. You need to load paper correctly. For details, see Load Paper on your manual. Set the toner cartridge in the machine. For details, see Install Toner Cartridge of your manual as well. Hope this helps.
Mar 11, 2011 | Computers & Internet
New toner loaded but still shows load toner mssage...
check the toner supply unit, maybe the toner is blocked inside the hopper.
Nov 04, 2010 | Ricoh Aficio MP 1600L Black and White...
My gestetner 2712 has ran out of toner. i have replaced the toner, the machine takes a while to load and then comes back with load toner again. Why would it not be registering a full toner bottle?
GESTETNER 2712 PROBLEM USUSALLY SIMILAR TO RICOH 2022/1022/27 PROBLEM IN WHICH INLET IN PCU AT LOAD TONER OUPUT. wHAT YOU CAN DO ,TEK OUT THE PCU IN CHECK IF THE PCU TONER INLET IS BLOCK EITHER BY SEAL OR DUE TO INLET CLOSER MALFUNCTION CAN BE REPAIRED IF YOU HAS EXPERIENCE OPENIG UP THE PCU
Apr 06, 2010 | Gestetner 2712 Digital Imaging System...
Ricoh SP 8100DN will not load toner
The SP 8100 is a BW printer only, it doesn't take color toner.
Mar 23, 2010 | Ricoh SP 8100DN Aficio Laser Printer
Does not load toner
make sure the cap is not stuck in ther machine from the old toner. very common problem. not the hard black plastic on you unscrew but the clear plastic one the hanlde removes as you close the hopper or handle. also the toner motors do burn up and willnot load toner. you will need a tech. also the dv fears go bad and make it look like a toner problem but you may need a pcu as the toner sensor is in the pcu. good luck
Oct 27, 2009 | Ricoh Office Equipment & Supplies
Studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Mar 19, 2009 | Office Equipment & Supplies
Copier will not load toner
Did you install a new toner bottle? If so did you remove the pull tab or tape that seals the toner from spilling out. If it is a new toner that you know of, do you have another to install. It may be a defective toner. From what you explaining it sounds like there is no toner in the developing unit. Try antother toner first...
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
Brother HL-5240 Laser Printer Logo
18 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
