Question about Sharp AR-168D Black and White Copier
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Posted on Oct 08, 2012
007tech
  • 95 Answers
SOURCE: I have an error code of L3-00 on my Sharp AR 168D.
L3-00 indicates scan carriage motor trouble. The carriage with all the mirors on it is not moving at all (scanning) or is not moving at the required speed so it does not reach its "home" position. If restarting the copier does resolve the issue....
A few things to check... When you turn copier on does carriage move at all? if not then the motor could be bound up (not turning) - also make sure the cables pulling the carriage are properly wound. remove the main glass and make sure there are no obstructions in the way of the carriage (a loose cable maybe or dirt) can you move the cable by hand freely? if the motor locks up it could be really hard to move the carriage.
The carriage seems to be moving freely (by hand and when you turn the copier on) it could possibly be the "home position" sensor that is faulty and not reading the correct position of the carriage.
You can the copier in test mode to check either the motor or sensor. press the following keys one after the other # * C * then press start/enter , press 1 and start/enter again, sub code 1 will test the motor and sub code 2 will test the sensor.
So it could be a bad motor or sensor or the MCU board that drives the motor (or may just need a good cleaning).
Good Luck.
Posted on Mar 26, 2009
taran_2005
  • 10515 Answers
SOURCE: Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Posted on Jun 11, 2009
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
SOURCE: Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Posted on Feb 11, 2010
  • 2072 Answers
SOURCE: Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Posted on Aug 03, 2010
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
Aug 03, 2010 | Sharp AR-168D Copier
Hi, Can someone help with resetting error H2-00 on sharp 168d
H2 00
[Content]
Thermistor open
[Detail]
The thermistor is open.
The fusing unit is not installed.
Cause Thermistor abnormality
Control PWB abnormality
Fusing section connector disconnection
[Check and remedy]
Check the harness and the connector between
the thermistor and the PWB.
Use TC 14 to clear the self diagnostic display.
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
Enter 14 Start to clear the code.
Oct 26, 2009 | Sharp AR-168D Black and White Copier
Error H3-00
Aug 26, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
I have a sharp 1r-168d copier. I have replaced the fuser assembly and now have a H2-00 error. I am unable to enter the servicemans mode to clear the self diagnostics
follows:
then enter Sim 14 then hit the start button and restart the machine.
Jun 23, 2009 | Sharp AR-168D Black and White Copier
Check
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Jan 12, 2009 | Sharp AR-168D Copier
Sharp AR-168D Black and White Copier Logo
136 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
